Re: Air cleaner base for 67 RT to get some clearance
[Re: p d'ro]
#2091980
06/14/16 06:52 PM
06/14/16 06:52 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
What are you using for a carb ?
If you used a stock tin valley pan it's the increased height of the intake causing your issue .
Is the aircleaner top rubbing the hood or do you have a hood pad ?
[Re: p d'ro]
#2092035
06/14/16 09:07 PM
06/14/16 09:07 PM
Posts: 5,164 CT
GTX MATT
CT
I haven't used it myself, you can buy an assorment of air filter "spacers" to raise it back up some. I think its a standard drop though, most are 1.5 inches, so you may have the same issue with any drop base. I had to run an aisr filter spacer with my drop base to avoid interference with the throttle linkage. Its either that or get a shorter filter I think. Sounds like you just need about half an inch though...
[Re: bobby66]
#2092399
06/15/16 01:01 PM
06/15/16 01:01 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Or, space the K-frame down a wee bit. And what would that do to the suspension geometry? Might be opening up a bigger can of worms, especially if it's not just a drag racer.
[Re: burdar]
#2092411
06/15/16 01:23 PM
06/15/16 01:23 PM
Posts: 1,584 MD
p d'ro
MD
The most drop you can have on your base and still clear an Edelbrock choke is 3/4". I was able to fit a 1" drop base on mine with a little modification to the base. The base modification did require a slight mod to the air filter element too. Great info. I will take a ball peen to it if need be. I guess I should get an aluminum one...
[Re: terzmo]
#2125696
08/05/16 01:44 PM
08/05/16 01:44 PM
Posts: 1,584 MD
p d'ro
MD
I used a drop bottom that wasn't as large as the top dual snorkel but with a filter to match the bottom,it worked fine as all the air still had to come through the filter and the base was not visible..67R/T with a 440..now hemi Exactly what I did. Glad to know it will work and still perform. How easy was the hemi swap. Not much room to work with my 440 and PS/PB. Getting off driver exhaust manifold a bear. Had to jack up motor.
