Re: nail in tire, how to fix?
[Re: RapidRobert]
#2092148
06/14/16 11:53 PM
06/14/16 11:53 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Use lots of rubber cement on the plug, lots and lots of it.
[Re: RapidRobert]
#2092152
06/14/16 11:56 PM
06/14/16 11:56 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
The first plugs that I recall was about 50 years ago. I was hanging out at the gas station one day and this guy drives up. Ask the owner if he plugged flat tires, he said no, the sales guy say's can I show you something? As they walked out to his car the guy took out a ice pick and stabbed his front tire in the sidewall. The tire looked like a chia pet it had so many plugs in it. Anyway the guy took a plug out of his kit and plugged the leak, then asked , you want to buy a kit? The owner of the station said yes. I have a plug kit that I take everywhere for emergency's, but when possible I use the plug patch system where the tire has to be removed from the rim, proper clean and prep for the patch then the plug is pulled through from the inside of the tire to seat the patch correctly. Never had a tire fail from this procedure. I wouldn't recommend doing a sidewall though.
[Re: Supercuda]
#2092213
06/15/16 01:56 AM
06/15/16 01:56 AM
RapidRobert
Use lots of rubber cement on the plug, lots and lots of it. Noted! don't want no leaks
[Re: RapidRobert]
#2092216
06/15/16 01:59 AM
06/15/16 01:59 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
No need for lots of cement if you use the black plugs.The gray ones we got fro tech used cement.Never had one leak of either unless they werent installed right.The ones with the patch and plug are good.used them on bigger holes.Rocky
Chrysler Firepower
[Re: RapidRobert]
#2092633
06/15/16 07:39 PM
06/15/16 07:39 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Thousands of brown rope like plugs used at my NapaAutoCare Center in Atlanta without one issue. Never in the sidewall. Never used on a race car tire.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#2092685
06/15/16 09:39 PM
06/15/16 09:39 PM
RapidRobert
Today I stopped by my tire guys' shop on the way to the store & he was not in but a co worker opinionated that the plugs are intended to get you from stranded into the tire shop and extended use can let air get inbetween the cords (I think he said cords,maybe beads) as mentioned here but of course that is his job is to steer people (business) into the shop. I will find out tomorrow where the puncture is & if it is in the trunk or still being driven on
[Re: RapidRobert]
#2092745
06/15/16 11:38 PM
06/15/16 11:38 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
A properly installed plug will never leak air to separate the plys at the cords, and protects the cords from contamination from outside debris. While a patch seals the hole from the inside, it leaves the hole in the tread open and there is the possibility of cord damage from water or debris.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: 62maxwgn]
#2092834
06/16/16 02:59 AM
06/16/16 02:59 AM
RapidRobert
yes top notch info has been provided to my inquiry. Tomorrow I will find out where the nail entered/if still in there/if the tire has been changed out
[Re: RapidRobert]
#2092879
06/16/16 09:31 AM
06/16/16 09:31 AM
therocks
Niles , Ohio
The tire guy is not on the up and up.Ive plugged tires for at least 35 years or more.Only leaks is if not installed right or the hole is too big.Nail goes into tire plug goes into hole.plain and simple.Quality plugs last.Only way to get air into plys IMHO is if nail went in sideways and went thru plys and then into air space.but like anything it can happen like a bubble on sidewall etc.99.9999 % of the time it will not be a problem.Rocky
Chrysler Firepower
[Re: minivan]
#2093178
06/16/16 08:58 PM
06/16/16 08:58 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
Drive it to the tire store and get it repaired? We have a winner!
[Re: NANKET]
#2093193
06/16/16 09:38 PM
06/16/16 09:38 PM
RapidRobert
Today she said that her husband was checking tire pressures & he noticed the nail & it is in the tread. She also stated that he has been driving it since (~3 weeks now), not sure if daily but I would assume so (did I mention that she said he ain't mechanically inclined!). She said he ran across some one who has some equipment & he might end up taking care of it for him. she said that if he dawdles or the other person don't come thru then she will get back to me on it & if that happens I am going to get a plug kit & plug it from the outside as you have convince me that a plug will (likely) work fine with care. So we're dead in the water (for now). thanks guys!
