Re: 440 Power Timing, cant get above 2350 rpm in park
[Re: stumpy]
#2085257
06/03/16 02:55 PM
06/03/16 02:55 PM
RapidRobert
by pulling/capping the can I wanted to elim Rotor Phasing as the culprit as RP has a special place in my heart (Please dont ask!). Nothing further is hitting me at the moment but the guys here will uncover it, just keep after it/be patient (pray for sunshine)
[Re: brando]
#2091232
06/13/16 02:57 PM
06/13/16 02:57 PM
RapidRobert
it would not hurt to just barely moisten the 1/4" nubs. yes the plate shifts a bit eccentric when the weights swing out. If you twist the rotor & let loose & it snaps back you are set on that Q. Now you will be going back inside to finalize the spring combo several times at least to get it dead on
