My Turn, New Best w/the "Street Car" Hemi Cuda....
#2089916
06/11/16 12:26 AM
06/11/16 12:26 AM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Well, its been a long time and coming, but I have been wrenching my butt off on everything and I mean, I am sore, tired and just plum wore out. This car, the 70 Cuda with the Big Hemi was never really meant to be anything but a show poodle, and over the years, I have finally put all the right parts on it.....Almost.
Off the trailer, thru the mufflers, on "street" DOT tires....6.47 first pass untouched!
Incrementals were 1.391 60ft, 4.12 at 330ft and 6.47 at 102.99mph in the 1/8th...Front end bouncing as it kept try to lift the front off the ground as it unloaded the rears.
2nd pass, a 6.48 with me lifting completely out of the throttle twice as traction is now a big issue....Broke the tires loose in 1st, 2nd, and then the shift into 3rd....
Incrementals were 1.40 60ft, 4.12 at 330ft and 6.48 at 104.66mph at the 1/8th...
Made some suspension adjustments, lowered tire pressure some more, dialed a 6.45 thinking if it hooks, I am going to have to hit the brakes....
Final pass 1.392 60ft, 4.08 at 330ft and 6.37 at 107.15mph! Didn't lift cause I bulbed it....
Now realize my mufflers weight a ton and shrink down from 3.5" header flange to 3" and probably kill a bunch of horse power, and the Thumper carb worked awesome. I can't say enough of how good this carb is out of the box and how close it is running to optimal already.
I am going to lean it down a tad for this Sunday's outing which will put it right back to where it was jetted when it showed up....Plugs showed color was a tad rich as the AFR gauge said. Dominic and I have talked about settings and different conditions the AFR has read, and every step of the way, its gotten better as we discussed what to do and dialed it in one change at a time. Went from overly lean cruising to almost a tad rich, but very drivable, and should be right on this Sunday I think. You always want just a little rich on a new engine, and I didn't even have 100 street miles on this combo yet.
Also, we never re-set the valve lash while hot which is loose yet, and the timing is not optimal yet either...
The only thing that did not survive was the straps on the diaper we are required to run...Those melted off, and the Gopro is giving me fits...I will post vids if I ever get this stuff all off the card and uploaded.
Re: My Turn, New Best w/the "Street Car" Hemi Cuda....
[Re: justinp61]
#2089943
06/11/16 12:55 AM
06/11/16 12:55 AM
Posts: 4,704 Wichita
GY3
Wichita
[Re: DARTH V8Я]
#2089948
06/11/16 01:06 AM
06/11/16 01:06 AM
Dragula
Vid says 1hr 45min to load to you tube.....And man, it leaves in the vid! There are 6.20's in this car, I know it.
Can't see the AFR or the tach in this vid...My race car I have no issues using the Gopro, but it seems I may have to do things a bit differently in this car.
[Re: Dragula]
#2089962
06/11/16 01:41 AM
06/11/16 01:41 AM
Thumperdart
State of confusion
Get it to hook and hang on man.......I can say that my "street tire" dayz are probably behind me cos NOTHING hooks like a slick for me on my heap and radials are out forever and have no problem street driving w/slicks. Can`t wait to check out the vid and hear the results from your next outing............ ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) More there when the 60 comes around......
[Re: Dragula]
#2089989
06/11/16 02:41 AM
06/11/16 02:41 AM
Posts: 368 michigan
turbo toad
michigan
Soild first time out with the new parts congratulations on the new best does it have stock suspension?
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: Dragula]
#2090032
06/11/16 09:00 AM
06/11/16 09:00 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Randy, is that your 605? If it is drop the mufflers, leave the jetting lone and put on some slicks and hang on! The mufflers are killing it, with my small heads, 3-1/2" collectors, pipes and Ultra-flows in place it killed 117hp and 97ftlbs.Dave
[Re: quickd100]
#2090163
06/11/16 03:29 PM
06/11/16 03:29 PM
Dragula
Randy, is that your 605? If it is drop the mufflers, leave the jetting lone and put on some slicks and hang on! The mufflers are killing it, with my small heads, 3-1/2" collectors, pipes and Ultra-flows in place it killed 117hp and 97ftlbs.Dave I know they are, but they would only tech the car to 6.50....We wanted to ease into that zone before we get asked to leave....As it is now, they could boot us. I was very happy everything is holding up, car goes straight, and no issues really. Might tinker with the timing on the next outing, we will see. Summit totally screwed me on the belts...Had it out with them on the phone today...I have an e-mail stating the belts would be here yestarday, and nothing! Then they go on to tell me they didn't ship until 7/9 and wouldn't be here till next week....%&*%&$^^#^$&%*! Here is the vid...Sorry its so long, the wrist remote would not work. Just skip to 3:28..Need to put the camera in a better spot. https://www.youtube.com/watch?v=jGmrkczPSX8
[Re: Dragula]
#2090351
06/11/16 11:18 PM
06/11/16 11:18 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
1.39 !!!! Well done, that is awesome. Please tell me about the rear end suspension, my 71 street cuda with caltrac just went 1.65 with a 10.1 134 on a old 28" slick. How can I go 1.40's ??? Again well done.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ozymaxwedge]
#2090353
06/11/16 11:22 PM
06/11/16 11:22 PM
Thumperdart
State of confusion
At that et you should be at LEAST in the 1.40`s or better unless it real heavy.........you know the drill, test and test some more......
[Re: ozymaxwedge]
#2090375
06/12/16 12:12 AM
06/12/16 12:12 AM
Dragula
1.39 !!!! Well done, that is awesome. Please tell me about the rear end suspension, my 71 street cuda with caltrac just went 1.65 with a 10.1 134 on a old 28" slick. How can I go 1.40's ??? Again well done. Good question as I have never adjusted anything on it until this event.... Setup was put 200lbs on the drivers seat, adjust bars in lowest hole with 1/4 turn of pre-load.....Set the Rancho shocks on soft. Been that way probably 15 years. All I did Friday was stiffen the rear shock setting....
[Re: Dragula]
#2090406
06/12/16 01:17 AM
06/12/16 01:17 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Actually this make me feel good. I notice your mph went up on the best pass. I have spun the tires every pass i made this year and have been very concerned that my mph was down.
Good day at the track. Congrats
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: quickd100]
#2090504
06/12/16 09:27 AM
06/12/16 09:27 AM
Posts: 10,018 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Randy, is that your 605? If it is drop the mufflers, leave the jetting lone and put on some slicks and hang on! The mufflers are killing it, with my small heads, 3-1/2" collectors, pipes and Ultra-flows in place it killed 117hp and 97ftlbs.Dave Bingo ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
