indy rockers sb #208719
01/30/09 04:15 PM
01/30/09 04:15 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Will their rockers for their 360-1 & 360-2 heads fit a w5 head?
If so are they any good?
Also how long will the mopar/crane blue rockers hold up for a 230 lbs seat pressure and 630 open?
Re: indy rockers sb [Re: sshemi] #208720
01/30/09 04:38 PM
01/30/09 04:38 PM
Canada
lenweiler Offline
lenweiler  Offline
Canada
With those pressures, I'd want Erson or at least Harland Sharp rockers.
Shady Dell just finished 360-1 heads for me and I opted for T&D rockers over the Indy stuff...
Damn! I dropped my change.............
Re: indy rockers sb [Re: sshemi] #208721
01/30/09 04:48 PM
01/30/09 04:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have those pressures with my W-5 and the Mopar
blue roller tip rockers... they've been fine...
I believe you need the offset shafts and stands
but to be sure I'd have to look at mine
Re: indy rockers sb [Re: MR_P_BODY] #208722
01/30/09 05:42 PM
01/30/09 05:42 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
I already have the shafts and stands and rockers but the shafts and stands are for Harland sharps i dont know if the oiling is edaqute (sp?) for the non bearing mopars
Re: indy rockers sb [Re: lenweiler] #208723
01/30/09 05:43 PM
01/30/09 05:43 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Two harland sharps are broken and the geometri is poor.
Re: indy rockers sb [Re: sshemi] #208724
01/30/09 05:53 PM
01/30/09 05:53 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I have the 360-2 heads and I needed some rockers. RyanJ told me the Indy rockers were ok for small cam stuff but wouldn't last but maybe 200 runs before they started breaking. I'm saving for T&D since I'm still building the motor.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: indy rockers sb [Re: Jacob Pitt] #208725
01/30/09 06:23 PM
01/30/09 06:23 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Dont the T&Ds require pushrod oiling?
Re: indy rockers sb [Re: sshemi] #208726
01/30/09 06:37 PM
01/30/09 06:37 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I am using the Jesel sportsmen rockers(pushrod oil)on my w5's and couldnt be happier. Dont know how anything could work any better than these do, excellent geometry, and probably cheaper than Sharps even, and definately better.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: indy rockers sb [Re: sshemi] #208727
01/30/09 06:43 PM
01/30/09 06:43 PM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
i have the t&ds on mine with factory oiling.had the indys on mine did not last 100 miles before i broke a rocker arm and went thur 6 pushrods due to lack of oil due to spring pressure.
Re: indy rockers sb [Re: sshemi] #208728
01/30/09 07:05 PM
01/30/09 07:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Either way on the W-5s
Re: indy rockers sb [Re: MR_P_BODY] #208729
01/30/09 07:22 PM
01/30/09 07:22 PM
canada,NB
jb15 Offline
jb15  Offline
canada,NB
T&Ds-8120 kit, oils thru the shaft to rocker tip.
9.19@145.3mphwith 1.27- 60s 2,800lb, sb.
Re: indy rockers sb [Re: MR_P_BODY] #208730
01/31/09 09:20 AM
01/31/09 09:20 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Do the shafts have banana grooves?
On my shafts the holes in the shaft fit the oiling hole in the rocker to the roller perfect but not for the pushrod so im thinking either a banana groove or drill an extra hole to the pushrod hole.
Or is oil spread out on the whole inside of the rocker so i dont need to do anything?
The Harland sharps doesnt even have roller oiling.
I measured rocker ratio today.
The Harland sharps where spot on at 1,5 even on the intakes (which should be a little more than 1,5 cause of the p-r angle). The blue mopars where actually close to 1,56.
The mopars have near perfect geometry so i think im gonna use the mopars.
Re: indy rockers sb [Re: sshemi] #208731
01/31/09 10:22 AM
01/31/09 10:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm pretty sure mine dont have banana grooves, its
been a while since I looked at that(engine is on
the stand, its a back up now). I have a set of TD's
that I'm fitting to the heads now
Re: indy rockers sb [Re: MR_P_BODY] #208732
02/01/09 10:27 AM
02/01/09 10:27 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Are you gonna keep the mopar set up or will it be for sale?
Re: indy rockers sb [Re: sshemi] #208733
02/01/09 10:40 AM
02/01/09 10:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know yet, how soon would you need them. I'd
have to take a look at them and see how they look
Re: indy rockers sb [Re: MR_P_BODY] #208734
02/01/09 11:04 AM
02/01/09 11:04 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Well .. it all depends on how much you want but considering it would have to make across the little lake i can say that im in a hurry.
Re: indy rockers sb [Re: sshemi] #208735
02/01/09 11:11 AM
02/01/09 11:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Well I might go out to the shop today and if I do I
can eye ball them and get back with you on a price
Re: indy rockers sb [Re: MR_P_BODY] #208736
02/01/09 11:27 AM
02/01/09 11:27 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Thanks.
