Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: slantzilla] #2086466
06/05/16 04:22 PM
06/05/16 04:22 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Originally Posted By slantzilla
Another option would be to get a copy of the adapter plate Mark Goodman used to make and then find a used small block shield. That also allows you to use the 130 tooth flywheel, but puts the starter in the low position.
Lou (Dart 270) on the Slant board has the one I had made. I think he would loan it out so you could copy it.
Wish you hadn't suggested that. tsk laugh2
That's really the right direction I should be going, solves a lot of other issues down the road. work
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086524
06/05/16 05:51 PM
06/05/16 05:51 PM
New Mexico
Scott440 Offline
Scott440  Offline
New Mexico
Bullet proof vests don't use just a handful of layers. I don't know how much your supplies would cost but 30+ layers of kevlar plus epoxy around a bell means material costs beyond $100 for me. So I think the trans blanket suggestion was a good one, unless you really want to get the experience.
If you worked for an exotic car mfr (front engine/trans) and they wanted something more classy than a blanket I think this is a really good idea. You could even take it to the firing range and put a small caliber bullet through it as a simulation. I wouldn't bother with the carbon fiber.
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086536
06/05/16 06:10 PM
06/05/16 06:10 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Have you considered armoring the tunnel and floor (inside or out) instead of the BH? If the pieces can't reach you who cares where they go.
Boffin Emeritus
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086893
06/06/16 10:14 AM
06/06/16 10:14 AM
Minn
SportF Offline
SportF  Offline
Minn
I have said this many times before, if you had seen what happened, and what was left of a carbon fiber shield from a tranny that blew up in Eddyville in '13, you wouldn't even think of anything fiber. He almost lost a foot! That shield did NOTHING. Let me repeat that, it did nothing.
The way every body tries to fit a trans blanket, they don't work either. The trick is to put it over the trans, and wrap the ends around the torsion bars. You may need one simple brace to keep it off the headers on the driver side.
Think about this, at the track, I bet flywheels have killed more people than you'd would ever care to hear about. And some of those were in the stands.
Best of luck to you.
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: Scott440] #2086941
06/06/16 11:48 AM
06/06/16 11:48 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I hoping I can size/pre cut my fabric to prevent as much waste as possible. You are correct, enough layers to do the job will certaintly be more then a handfull.
Your comment on bypassing the CF instills me to ask your reasoning. My thinking, the OEM housing is over 1/4"+- alum, my first layers would be CF, as increasing the overall strength of the alum housing from failure, would be first goal in the event of an explosion, CF is close to stiffness of alum, plus it would likely slightly dampen the alum, and to a lessor degree, maybe protect the following added layers of kelvar, from any arising sharp edges of cracked/broken alum protruding outward. The problem with that scenario is, most of the CF I has seen that failed, has its own sharp edges. My understanding of Kelvar, besides its general robust strength, is its resistant to tearing/cutting, but it can be cut, so sharp edges are to be avoided. Then I was thinking another outside final layer again of CF, since the outside layer would be the first to fail from stress, in an explosion. I also pondered adding a thin form-able layer inside of a SS liner. I'm also thinking I'm talking myself into calling Summit. But that wouldn't be any fun. shock
PS "SportF", this ever saw the drag strip or higher powers, this idea would not be considered, and I cannot see it can do any harm, other then my wallet, nor am I trying to mislead others to follow this path.
"Poly", reinforcing the tunnel, would not protect nearby fuel lines, brake lines, tires, bystandersrs, etc
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2086964
06/06/16 12:17 PM
06/06/16 12:17 PM
Az
Crizila Offline
Crizila  Offline
Az
I can attest to the last line above. I do like "sport F's" suggestion of attaching a blanket to the torsion bars. Will look at doing that. Might help with my existing blanket / trans linkage clearance issues that I have.
Fastest 300
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: SportF] #2086974
06/06/16 12:36 PM
06/06/16 12:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You dont want a blanket tight... you want them to
stretch and absorb the energy... the C/F shields that
are SFI approved are there for a reason... the trans
itself helps slow the energy then the shield helps it
even more.. and they arent thick... you want things to
stretch to eat up the energy
EDIT
On a 727 if you break the sprag anything over 6200 rpm
will blow the drum.... based on the 2.2 times faster than
the engine rpm and based on testing that 13,000 rpm will
rip it apart.. and we know MOST people turn more than 6200
rpm.... but if you dont do stupid stuff you wont blow the
drum.. NEVER get out of it and get back on it if the sprag
is broke.. that extra distance will roll over the ramps...
if you get out of it SHIFT... low is when the sprag is engaged
granted in this post its a manual trans
wave
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: Scott440] #2086988
06/06/16 01:01 PM
06/06/16 01:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The vest that SAVED my life was a solid 3/4"carbon
fiber... the chopper crews wore them(most of the guys
sat on them... they were heavy and had just a front and
back with velcro straps to hold it on... I was hit in
the chest with part of a B-40 rocket... it blew me back
about 15' and I hit a guy behind me and I broke his nose..
a couple other parts got me.. one in the shoulder and one
in the side... but I walked away and still kept fighting
till I could be choppered out.. then the chopper was shot
down(about 60' up) but we all got out before they hit it
with a mortar round...C/F is STRONG stuff.... if I would
have had a normal vest on(the army style) I wouldnt be here
wave
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: MR_P_BODY] #2096121
06/22/16 10:51 AM
06/22/16 10:51 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I'm ending the project. I'm chickening out. After prepping the the used alum 50? year old housing, on close inspection there seems to be an awful lot of minute casting? cracks. When I started I dismissed them as casting lines, but after grinding away some threaded unneeded bosses, and discovering numerous porosity inclusions, I looked closer at the casting lines, my suspicion, they are from thermal cooling shock when cast, or something, they don't look to be always in use stress related, although some do. Bottom line, not worth trying to make a safe silk purse out of a pigs ear. I'll get the QT bellhousing, save my efforts for something else. Below are a couple of pics on my added lower cover retaining holes. I also under stand there are few if any good methods to locate cracks in alum. Is this a rarity what I am seeing, or common?
bell bottom.jpgIbell crack_edited-1.jpgbell crack 2_edited-1.jpgbell crack 4.jpg
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: jcc] #2096229
06/22/16 02:11 PM
06/22/16 02:11 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Granger has a nice spray can Kit that works great.
https://m.grainger.com/mobile/product/SPOTCHECK-Penetrant-3WU63
Re: Kevlar/CF laminating an OEM Alum manual bellhousing, Crazy? [Re: FastmOp] #2096288
06/22/16 03:54 PM
06/22/16 03:54 PM
dogdays Offline
dogdays  Offline
Dye penetrant testing will find the surface cracks. Magnaflux makes a kit, looks like the Grainger kit is similar. Zyglow is kind of cool, the penetrant glows under UV light.
The cracks you have circled are indeed from the casting process. They're not at all unusual. The case is adequate for its intended use, as are most things Chrysler. They had the attitude that if a racer need something specialized he'd get it. Those cracks are perfectly fine for driving to the beach or Love Shack in your "Chrysler as big as a whale" that "seats about twenty".
Yeah! Love Shack Baby!
R.
