Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside
[Re: GoodysGotaCuda]
#2082900
05/30/16 04:37 PM
05/30/16 04:37 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Nice! Whats going on in the radiator support?
Mopar to the bone!!!
#2082907
05/30/16 04:56 PM
05/30/16 04:56 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Do they make a kit to put a T 56 into s A body?
A new iron curtain drawn across the 49th parallel
[Re: 72Swinger]
#2082908
05/30/16 04:56 PM
05/30/16 04:56 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Nice! Whats going on in the radiator support? Thats a US Car Tool part. Not the biggest fan of that one, but it's on there.
[Re: 67autocross]
#2082909
05/30/16 04:58 PM
05/30/16 04:58 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Do they make a kit to put a T 56 into s A body? Due to the amount of cutting that's needed, there isn't really a "kit" to use while maintaining torsion bars for any of the Mopar flavors. I bought from SST, they have an Ebody and Bbody kit that comes with a lower mount, so the upper crossmember is up to you. If you remove the torsion bars in favor of coilovers, there is a substantial reduction in load going through that area. ...as far as Abodies go, you'd have to get with SST or American Powertrain.
#2085146
06/03/16 12:06 PM
06/03/16 12:06 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
Are you running the shifter in the as delivered location or rotating the plate so it sits forward? Might help clear the torsion bar crossmember...
[Re: ntstlgl1970]
#2085476
06/03/16 08:21 PM
06/03/16 08:21 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Are you running the shifter in the as delivered location or rotating the plate so it sits forward? Might help clear the torsion bar crossmember... As installed. I don't think moving the shifter forward will help much, there is heavy interference with the transmission and crossmember. If you have to cut the majority of the crossmember out, you might as well stick the shifter where you want it. That upper crossmember was lowered for final install, this photo was right after welding it together.
#2085508
06/03/16 08:53 PM
06/03/16 08:53 PM
72Swinger
Nebraska
Does that shifter location land in the factory console hole?
[Re: 72Swinger]
#2085512
06/03/16 08:55 PM
06/03/16 08:55 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Does that shifter location land in the factory console hole? Doubtful, its centered on the hump and i think the factory 4spd is offset to the drivers side.
#2085531
06/03/16 09:18 PM
06/03/16 09:18 PM
ntstlgl1970
Sac, CA, USA
I already did major surgery on my upper crossmember for the 518, hoping not much more is needed for the t56, thanks for the photos
[Re: 71sat440]
#2104583
07/06/16 12:23 AM
07/06/16 12:23 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Holly crap is that a wooden whirly jig? How the heck does it work, and is there a build thread? Ahyup, whirly wooden jig. Only a half whirly wooden jig though. No build thread, just an afternoon with some screws, some wood, and a skill saw.
