Page 4 of 4 1 2 3 4
Re: 360 Block Question [Re: slantzilla] #2089658
06/10/16 02:48 PM
06/10/16 02:48 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Originally Posted By slantzilla
But would a stock 360 block live well at 500 horse?
I know plenty were killed at 180hp laugh2
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: 360 Block Question [Re: slantzilla] #2089671
06/10/16 03:13 PM
06/10/16 03:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Yes. It may still want to make the main caps dance around a little and would need some oil system help to keep it happy if you spin it up.
Re: 360 Block Question [Re: DARTH V8Я] #2089675
06/10/16 03:20 PM
06/10/16 03:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By DARTH V8Я
120 runs for me would be over 60 years lol
Me too............... laugh2
Re: 360 Block Question [Re: slantzilla] #2089766
06/10/16 07:05 PM
06/10/16 07:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Granted mine is a 340 base 416.. it made 590 hp
525 tq on the dyno.. I had the pan off the other
day and pulled the #5 main so I could check the oil
pump... the bearing looked new...that was about 600
miles on it and just beating on it on the street..
turning 7200rpm.... thats with my W-2s.. I want to
change over to my W-5s or pull the engine and put my
395ci in it... the 395 ran 9.50s in the race car.. but
for a street/strip rod I wanted the extra torque.. but
I didnt even advance the cam for more torque because of
the conv.. its already 5000 stall and I didnt want it any
higher... based on that article those Indy alum heads put
out more power by a lot... I'm running less cubes, less valve
diameter on both, less lift but I run a solid roller...my
heads flow 305 but dont remember if thats at .650 or .700
but I believe its .650.. when dynoed it was with a 850 cfm
and now I run a 1000 cfm throttle body multi ported injection
so I have no idea if its more,less or what on power.. that
was dynoed on 93 octane.. most of the time I run 87 octane
and beat on it pretty good(up to that 7200 rpm)..
I also use chevy rods at 6.125 and Diamond pistons
at 10.6 compression..could be 10.4.. I forget which
gaskets are on it now.. but it runs great on moose pi$$
wave
Re: 360 Block Question [Re: clonestocker] #2089785
06/10/16 07:45 PM
06/10/16 07:45 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Never had a problem with a steel crank 340. Stock bottom end except for pistons, 7800RPM. Ran all year with no issues. I started fooling with 360s and it was a different story.
Re: 360 Block Question [Re: CMcAllister] #2090035
06/11/16 09:38 AM
06/11/16 09:38 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Just over 200 10-second timeslips and thousands of street miles since refresh.
Mid-10's @ 130+ mph at 4190# race weight.
Best mph: 133.65
700+ hp?
Stock '99 Magnum 360 block here.
No fill.
No girdle.
Stock 2-bolt mains with stock bolts.
Forged, internally balanced lower parts with a turbo.
It's all completely happy with a 7,000 rpm rev limiter, 6800 in the lights.
Built it in 2004.
Hurt 2 pistons in 2007. (tune)
All bearings looked great.
Minimal evidence of cap walk - but did spin it to 7500 quite a few times.
Refreshed it and continue to put laps/miles on it.
If it broke tomorrow I'd still say it lived a long and happy life.
Hopefully it doesn't break though. LOL
Re: 360 Block Question [Re: Duner] #2090058
06/11/16 11:56 AM
06/11/16 11:56 AM
Az
Crizila Offline
Crizila  Offline
Az
Best mph: 133.65
700+ hp?
No fill.
No girdle.
Built it in 2004.
Always impressed with your truck Duner. Also have many 10 second passes. Best = 10.50 @ 128.38 mph. 3600 lb race weight.
Fastest 300
Page 4 of 4 1 2 3 4
