US Car Tool Chassis Kit + T56 Magnum Cuda Underside #2082874
05/30/16 03:50 PM
05/30/16 03:50 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Sharing the picture for other's reference of what torsion bar crossmember modifications are needed for a T56 Magnum as well as adding a USCarTool Chassis Kit.
I also added the forward 3x3" square from the torsion bar crossmember to the forward frame rail to help make up for the loss in material over the trans crossmember.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda] #2082900
05/30/16 04:37 PM
05/30/16 04:37 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Nice! Whats going on in the radiator support?
Mopar to the bone!!!
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda] #2082907
05/30/16 04:56 PM
05/30/16 04:56 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Do they make a kit to put a T 56 into s A body?
A new iron curtain drawn across the 49th parallel
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: 72Swinger] #2082908
05/30/16 04:56 PM
05/30/16 04:56 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thats a US Car Tool part. Not the biggest fan of that one, but it's on there.
2020 RAM 1500
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: 67autocross] #2082909
05/30/16 04:58 PM
05/30/16 04:58 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Due to the amount of cutting that's needed, there isn't really a "kit" to use while maintaining torsion bars for any of the Mopar flavors.
I bought from SST, they have an Ebody and Bbody kit that comes with a lower mount, so the upper crossmember is up to you. If you remove the torsion bars in favor of coilovers, there is a substantial reduction in load going through that area.
...as far as Abodies go, you'd have to get with SST or American Powertrain.
2020 RAM 1500
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda] #2085146
06/03/16 12:06 PM
06/03/16 12:06 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Are you running the shifter in the as delivered location or rotating the plate so it sits forward? Might help clear the torsion bar crossmember...
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda] #2085214
06/03/16 01:47 PM
06/03/16 01:47 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
And the rotisserie? work
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: 67autocross] #2085375
06/03/16 05:59 PM
06/03/16 05:59 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
https://www.facebook.com/ToddRonRestorations/photos/?tab=album&album_id=347827735323636
ToddRon Restorations sells a kit.
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: ntstlgl1970] #2085476
06/03/16 08:21 PM
06/03/16 08:21 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
As installed. I don't think moving the shifter forward will help much, there is heavy interference with the transmission and crossmember. If you have to cut the majority of the crossmember out, you might as well stick the shifter where you want it.
That upper crossmember was lowered for final install, this photo was right after welding it together.
Screen Shot 2016-06-03 at 5.23.16 PM.pngScreen Shot 2016-06-03 at 5.25.54 PM.png
2020 RAM 1500
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: jcc] #2085477
06/03/16 08:22 PM
06/03/16 08:22 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
It's not termite-proof, but it is cheap!
2020 RAM 1500
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda] #2085508
06/03/16 08:53 PM
06/03/16 08:53 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Does that shifter location land in the factory console hole?
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: 72Swinger] #2085512
06/03/16 08:55 PM
06/03/16 08:55 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Doubtful, its centered on the hump and i think the factory 4spd is offset to the drivers side.
2020 RAM 1500
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda] #2085531
06/03/16 09:18 PM
06/03/16 09:18 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I already did major surgery on my upper crossmember for the 518, hoping not much more is needed for the t56, thanks for the photos
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda] #2085654
06/04/16 12:36 AM
06/04/16 12:36 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
I was able to get mine through the console, had to move it an inch or so.
http://www.forabodiesonly.com/mopar/attachments/dsc03071s-jpg.1714709321/
http://www.forabodiesonly.com/mopar/attachments/p82a04281s-jpg.1714712338/
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: 72Swinger] #2085658
06/04/16 12:45 AM
06/04/16 12:45 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
ToddRon's kit is for use with the "Ford" version of the T56 Magnum and the matching Quicktime bellhousing for a small block. I started with his kit and modified it heavily to get it to work with a "GM" version of the T56 Magnum and the matching bellhousing for a big block. APT recommended to me to go the with the combo I did for some reason due to the clutch, I don't remember the details. The ToddRon kit is quite stout and does require considerable fabrication even as is for a small block.
http://www.forabodiesonly.com/mopar/attachments/p82a0231-jpg.1714678367/
http://www.forabodiesonly.com/mopar/attachments/p82a0246-jpg.1714680787/
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda] #2085663
06/04/16 12:51 AM
06/04/16 12:51 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda] #2104580
07/06/16 12:20 AM
07/06/16 12:20 AM
Willow Grove PA
71sat440 Offline
71sat440  Offline
Willow Grove PA
Holly crap is that a wooden whirly jig? How the heck does it work, and is there a build thread?
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: 71sat440] #2104583
07/06/16 12:23 AM
07/06/16 12:23 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Ahyup, whirly wooden jig. Only a half whirly wooden jig though.
No build thread, just an afternoon with some screws, some wood, and a skill saw.
2020 RAM 1500
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda] #2105202
07/06/16 08:37 PM
07/06/16 08:37 PM
Willow Grove PA
71sat440 Offline
71sat440  Offline
Willow Grove PA
Bottom pic looks like it has more additional bracing against the rear rails.
Where you able to tilt that yourself?
My car is a bare sandblasted shell.
I've been dreading the day I go to weld in the uscartool frame connecters I got last year at Carlisle.
I can't afford a 1k+ for a rotisserie and have come to accept I will be welding these things on my back in complete misery.
This is one of the coolest home depot solutions I've seen. Just wondering how you achieve a controlled flip.
Re: US Car Tool Chassis Kit + T56 Magnum Cuda Underside [Re: GoodysGotaCuda] #2105223
07/06/16 09:04 PM
07/06/16 09:04 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Great Tilt stand.
Great work.
