Spring perch mount width HELP F Body
#208137
01/29/09 08:29 PM
01/29/09 08:29 PM
Posts: 1,951 Toronto Ontario
Butt Ugly
Toronto Ontario
Any help out there guys. I can't measure my Volare right now and my buddy needs the measurments. I am installing a B body 8 3/4 in my Volare. Would it be best to tell the guy doing it inside to inside measurements?? Thanks in advance for any help, info. Not to go on and on but read somewhere that I should toss the rubber bushings and install A/B lower plates? Would I have to switch shocks? Thanks again for any help. Jeff
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
Re: Spring perch mount width HELP F Body
[Re: 440newport]
#208141
02/01/09 11:57 AM
02/01/09 11:57 AM
Butt Ugly
Toronto Ontario
Thanks for all the info guys, had no idea I had to shorten drive shaft Read somewhere else "welding in a washer into the axle housing perch hole is the only fabrication need to switch to the A/B lower plates"
