Raditor fill question, #208106
01/29/09 07:56 PM
01/29/09 07:56 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I always wondered if on the stock radiator of the roadrunner you want it filled to the top or leave it a little low ( like an inch below the cap).
Re: Raditor fill question, [Re: MidPenMopar] #208107
01/29/09 07:59 PM
01/29/09 07:59 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
with no reserve/recovery system they are filled about to the level of the baffle plate that you can see looking into the neck. Must have room for expansion.
Re: Raditor fill question, [Re: MidPenMopar] #208108
01/29/09 08:00 PM
01/29/09 08:00 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I fill mine just touching the bottom of the filler neck. A little below is OK and you can see if it's flowing with an open thermostat. As long as it runs cool or at least with in the temp range, I think either is OK.
Mike
Re: Raditor fill question, [Re: MoparforLife] #208109
01/29/09 08:02 PM
01/29/09 08:02 PM
I just changed from a 7 PSI cap that has an overflow to 16 PSI cap. I still have the overflow hooked though, but i was thinking it should be a little low.
Re: Raditor fill question, [Re: MidPenMopar] #208110
01/29/09 08:13 PM
01/29/09 08:13 PM
with a recovery cap/bottle you would want it full to the ledge where the cap seals to purge as much air out of there as possible
Re: Raditor fill question, [Re: RapidRobert] #208111
01/29/09 08:17 PM
01/29/09 08:17 PM
Are all caps designed to let overflow happen or it is just specific ones?
Re: Raditor fill question, [Re: MidPenMopar] #208112
01/29/09 08:42 PM
01/29/09 08:42 PM
recovery caps have the thin piece of metal on the bottom side of the rubber seal about the size of a quarter & it dangles loose.
Re: Raditor fill question, [Re: RapidRobert] #208113
01/29/09 08:50 PM
01/29/09 08:50 PM
Thank you for the heads up. I will check it out.
Re: Raditor fill question, [Re: MidPenMopar] #208114
01/29/09 08:56 PM
01/29/09 08:56 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Recovery caps have an upper and lower rubber seal - one seals against the outside or upper edge of the neck, the other against the opening at the bottom of the neck.
Non-recovery caps only have one seal against the opening at the bottom of the neck.
Re: Raditor fill question, [Re: MidPenMopar] #208115
01/29/09 08:57 PM
01/29/09 08:57 PM
Upper Midwest
Upper Midwest
Yes all pressure caps are pressure release and will allow coolant to escape. Caps used with recovery systems have the added seal mentioned above that actually works in reverse to the pressure cap release to allow the coolant to return to the radiator from the recovery tank. This smaller valve perse' seals under the pressure to escape allowing the major seal of the cap to allow the fluid to escape to the tank and upon cool down a vacume is formed in the radiator opening this seal and allowing the coolant back in.
Re: Raditor fill question, [Re: MoparforLife] #208116
01/29/09 09:07 PM
01/29/09 09:07 PM
Great info, thank you all for taking the time to clue me in!
Re: Raditor fill question, [Re: MidPenMopar] #208117
01/29/09 09:21 PM
01/29/09 09:21 PM
Here's the cap i am using now.
Re: Raditor fill question, [Re: MidPenMopar] #208118
01/29/09 09:39 PM
01/29/09 09:39 PM
a recovery cap
Re: Raditor fill question, [Re: RapidRobert] #208119
01/29/09 09:58 PM
01/29/09 09:58 PM
a recovery cap
This one actually has a guage built into the top of the cap that tells you the temperture too.
Re: Raditor fill question, [Re: MidPenMopar] #208120
01/29/09 10:00 PM
01/29/09 10:00 PM
take a pic
Re: Raditor fill question, [Re: RapidRobert] #208121
01/29/09 11:02 PM
01/29/09 11:02 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
mine doesnt have a recovery tank and a stockish type (repro) cap. it likes the coolant an inch low. any higher and it spits its out to an inch low then im good
Re: Raditor fill question, [Re: MidPenMopar] #208122
01/30/09 06:27 PM
01/30/09 06:27 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
From the Service Manual page 7-5 under Installation: "(3) Fill cooling system to 1 1/4" below the filler neck seat with water and rust resistor or water and anti-freeze, as required. After warm-up, re-check coolent level.
Re: Raditor fill question, [Re: 474218] #208123
01/30/09 07:06 PM
01/30/09 07:06 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Which are fine instructions for a cooling system without an overflow/coolant recovery bottle (which was how Stu's vintage RR was originally delivered). The intent was to provide some headroom in the radiator for the expansion as things heated up, without puking some out onto the ground.
As stated before, with the addition of an overflow bottle, radiators should be filled to the top, with the "headroom" essentially being between the cold and hot lines on the overflow bottle.
To make it even simpler, if you start with a properly constructed overflow system and the radiator anywhere in the neighborhood of filled, a few cycles of going from a cold system to a hot system and then back to a cold system will take care of the level inside the radiator, provided you watch the level in the overflow bottle and adjust things there.
Down to just a blue car now.
Re: Raditor fill question, [Re: 68HemiB] #208124
01/30/09 08:53 PM
01/30/09 08:53 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
So I take it you think the Factory Service Manual is wrong?
Well I went back and read the cooling section throughly it made no mention of filling the radiator of a car with a coolent overflow system any differently. Then I did a little more reading and the first mention of a overflow coolent recovery system offered for B Body cars was in 1970 and I thought Stu's "vintage" RR was a 69? However I have been mistaken in the past.
Re: Raditor fill question, [Re: 474218] #208125
01/30/09 09:09 PM
01/30/09 09:09 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
I have no beef with you.
I believe that Stu's RR may not have had a recovery system on it originally, but seems to have one now.
I make no claims about the Factory Service Manual's accuracy. It is my opinion and pure speculation that the words you posted were written with a NON-coolant recovery system in mind, during a period of time when coolant recovery systems were not yet in wide use by Chrysler Corporation.
Knowing what we now know in 2009 about coolant recovery systems (by now, a mature system in wide use), there is no need to leave an air gap above the coolant in a radiator so equipped. If one leaves such an air gap, has coolant in the recovery bottle, and cycles the car through a few cold-hot-cold cycles, any such air gap will go away.
