TC lockup switch on '01 Cummins question... #2080122
05/25/16 04:34 PM
05/25/16 04:34 PM
an8sec70cuda Offline OP
If I do the TC lockup switch trick on my '01 Cummins Ram, will it only lockup manually by flipping the switch then? Meaning it will no longer do it automatically?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: TC lockup switch on '01 Cummins question... [Re: an8sec70cuda] #2080147
05/25/16 05:20 PM
05/25/16 05:20 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
It will still work normally when switch is off as long as you don't cut the wire from the PCM.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: TC lockup switch on '01 Cummins question... [Re: an8sec70cuda] #2080156
05/25/16 05:35 PM
05/25/16 05:35 PM
OK, thanks. No plans on cutting any wire...just install the jumper wire in place of the relay and the additional switched ground spliced onto the PCM wire.
Using these instructions...
http://www.tstproducts.com/Torque%20Converter%20Lockup%20Switch.pdf
My truck feels so much stronger when the converter locks it's ridiculous.
CHIP
