Page 4 of 6 1 2 3 4 5 6
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2077561
05/21/16 09:48 AM
05/21/16 09:48 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Originally Posted By DARTH V8R
Originally Posted By Thumperdart
Jason Pettis has seen 20+ hp per point..........
Really? Thats a lot. Personally seen a BBC that went from 10:1 to 13:1 with nothing else changed and it gain only 40hp. Now he has to run race gas. Maybe there's more gain going from 8:1 to 11:1 (same 3pt increase)?
I have nothing personally to back this up but from what I have read it seems the gains diminish as the compression gets higher. Much more to be gained from going from 8:1 to 10:1 than there is from 12:1 to 14:1.
The only downside to W2s in my opinion is that they are Iron. My Dad and I built a W2 headed 416 for drag week. We had to lower the compression some to know we would be safe on pump gas and its HEAVY. It took three full turns on the torsion bars to support the R1 W2 headed 416 over my aluminum headed 360.
68 Barracuda Formula S 340
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2077632
05/21/16 12:47 PM
05/21/16 12:47 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Well hopefully I'll get a PM about some W2's smile
Rockers Rockers Rockers
[img] [/img]
Re: FINALLY got me a 360.. [Re: Bad340fish] #2077662
05/21/16 02:12 PM
05/21/16 02:12 PM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
Try a 440 in a 73 Dart.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2077689
05/21/16 03:02 PM
05/21/16 03:02 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have no idea if this is a good deal or not, but here is a CL listing in Western Washington for Aluminum W2 heads
http://seattle.craigslist.org/tac/pts/5595446824.html
They are not mine, I don't need them, you can have them.
Good luck.
Corrected I first thought they were iron.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2077730
05/21/16 04:15 PM
05/21/16 04:15 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
W2 heads??? hey now you're entering cast crank power territory!
Re: FINALLY got me a 360.. [Re: J_BODY] #2077793
05/21/16 06:44 PM
05/21/16 06:44 PM
Its a TRAP!
Its a TRAP!
Sayin can't run 9's with an W2 Iron heads & cast crank?
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2077804
05/21/16 07:04 PM
05/21/16 07:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They will run in the 9s.. the thing about
W-2s you need to watch for.. they made them
in 2 different installed heights..1.88 which
is the standard lenght valve and then they made
a 2.00 installed height which use a long valve..
I have a set of each.. on my Rampage I am running
the long valve W-2s which I ported and they flow
310 at .650 with a 2.08 valve.. they could go a
little more but core shift might be a issue.. mine
have some core shift and I busted through 1 intake
runner when I was clearancing the push rods.. I had
to tube it... I run 9.56 with them.. thats with the
same cam I have in the 416 right now(.640 lift)...
they are a very good head but heavy.. alum heads will
knock off 40# for the pair... this 416 dynoed at 590hp
with a 950 carb
EDIT
Also when I ran that 9.56 it was with a 395ci
wave
Re: FINALLY got me a 360.. [Re: J_BODY] #2077979
05/21/16 11:23 PM
05/21/16 11:23 PM
Tucson, Arizona
Tucson, Arizona
I've got an E58 standard bore block under the bench. If cam is small enough you can use Crane rockers also. Have some of those in the drawer. Then they start to get expensive.
[img] [/img]
Re: FINALLY got me a 360.. [Re: MR_P_BODY] #2078031
05/22/16 12:31 AM
05/22/16 12:31 AM
Its a TRAP!
Its a TRAP!
with a 950 carb
EDIT
wave
That's some solid info. Thank you very much Mr P Body.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2078044
05/22/16 12:56 AM
05/22/16 12:56 AM
P
Porter67 Offline
Porter67  Offline
P
Mr. P... whats the length on the long valves your using?
Re: FINALLY got me a 360.. [Re: Porter67] #2078050
05/22/16 01:11 AM
05/22/16 01:11 AM
Its a TRAP!
Its a TRAP!
Probably 5.28" Stem Length.
Re: FINALLY got me a 360.. [Re: Porter67] #2078154
05/22/16 11:22 AM
05/22/16 11:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
5.40".... 5.29" is the stock length for the standard
length head(W-2 and W-5)
EDIT
Dont bother trying to use long valves in a short
valve head... it doesnt work... the pedestals are
in a different location.. unless you mill the stands
off and relocate them and the different height
wave
Re: FINALLY got me a 360.. [Re: MR_P_BODY] #2078250
05/22/16 01:54 PM
05/22/16 01:54 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Do lots of research before buying W2 heads to avoid some issues and to make sure you get the set-up you want or need. I bought a set of Econo W2 heads and picked up some Crane and MP W2 rockers. I did some port work and with the stock 2.02 valves they were flowing slightly over 300 cfm. I ported the W2 intake and threw it in my Duster. After cam break-in I started it a few times in the shop and noticed a small puddle of water on the passenger side. Sure enough the heads cracked on the outside lower row of bolts by the W2 cast into the head. I ground the crack out and used Splash-zone epoxy to fix it and headed to the track. My Duster ran high 9 with that combo but about 3 months later the drivers-side head cracked in the same spot and even after a quick repair the crack continued to grow. After some reading I found out that some of these casting were known to have that issue so they are both leaning again my shop wall in the SCRAP zone. I'm just glad I didn't go to the work and expense of installing bigger valves.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: FINALLY got me a 360.. [Re: pittsburghracer] #2078271
05/22/16 02:28 PM
05/22/16 02:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Other than what I said before I did forget to say..
that the W-2s can be bought in a race or econo version
which is simple to spot.. the race ones dont have the pedestals
for the rocker shafts.. the econo ones have the pedestals..
both sets of mine are the econo versions.. one set is the
short valves the other is the long valve... I have never
had the short valve ones on a engine yet.. I ported them
and there they set.. I didnt get carried away with the
port work on them so they didnt need any tubes added..
I think I have valves for them but I dont know... I might
look to see what I can run for max lift on them just in
case I want to put them on something... they should still
flow right at 300 which is pretty simple on the W-2s
wave
Re: FINALLY got me a 360.. [Re: pittsburghracer] #2078336
05/22/16 04:46 PM
05/22/16 04:46 PM
Washington
madscientist Offline
Washington
Do you want to sell those W2's. PM me if you do.
Re: FINALLY got me a 360.. [Re: madscientist] #2078517
05/22/16 11:26 PM
05/22/16 11:26 PM
Its a TRAP!
Its a TRAP!
Same. Or any body else.. Mr P? smile
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2078537
05/22/16 11:52 PM
05/22/16 11:52 PM
Its a TRAP!
Its a TRAP!
Have you guys tried that electric motor paint? I tried some of it.. for a base coat on the timing cover, pretty slick. Water pump was rattle canned.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2079161
05/24/16 01:47 AM
05/24/16 01:47 AM
Its a TRAP!
Its a TRAP!
LOL.
Original timing chain, no broken teeth. Valved move freely.. yet somehow both the Intake and exhaust valves clipped the piston (#8). Also the exhaust valve clipped
piston #2. Over rev much? smile
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2079169
05/24/16 02:21 AM
05/24/16 02:21 AM
P
Porter67 Offline
Porter67  Offline
P
Maybe it was cammed at one time???
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2079176
05/24/16 02:39 AM
05/24/16 02:39 AM
Its a TRAP!
Its a TRAP!
Dunno. I'll have to check the cam in it. The head gaskets were done (composite, black in colour). Intake rails & face had a bejesus amount
of silicon on em. Note; silicon blocking 1/2 the water ports aren't a good thing. That stock 2bbl intake weighs A LOT. Yikes lol.
