Your prefered minimum bearing clearances?
#2072475
05/13/16 09:32 AM
05/13/16 09:32 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I figure I don't want to go tighter than .00275 at an absolute minimum on 2.750 mains, .0025 0n 2.375 rods, and I am nervous about being that tight. I only figure I could get away with it due to running my motor so warm. What hp level and rpm would also be a factor, in my case 880 hp at 7500 max rpm. I don't think I am going to push it that tight on the mains, maybe .003 if the three sets of bearings I have will get me there. Rods, I won't go below .003 . What are your safe minimums?
Re: Your prefered minimum bearing clearances?
[Re: gregsdart]
#2072525
05/13/16 11:25 AM
05/13/16 11:25 AM
Posts: 368 michigan
turbo toad
michigan
Im in the same boat as greg and ill be starting the assembly process of my low deck within the next month and would like to know this info as well, Class is in session This will be the first stroker motor ive assembled im not looking to turn more then 7000rpms but the mill will see some boost and I'll be running e85. Thanks all
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: gregsdart]
#2072537
05/13/16 11:48 AM
05/13/16 11:48 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I like to run .003/.003 on my SB junk.. I do turn up the rpm... so that .003 is my min... .0035 is my normal max unless its a alum rod engine..I am talking race only
[Re: gregsdart]
#2072576
05/13/16 01:19 PM
05/13/16 01:19 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
People get stressed over large clearances, or what they perceive as large, but I have never seen them be a problem. Tight on the other hand, gets a you a pan full of shrapnel. 003 on mains and rods is generally my minimum, even on a driver motor. Alum rodded motors...........I don't know how many have ever heated one up and THEN checked it, but an alum rod that has .003 cold, can be .005 or better at 150* and they never present a problem. Less than .003 is just too tight for my tastes.
It was mentioned about "getting away with it" because you run your engine warm. Well it isn't warm when you FIRST fire it and THAT is when 90% of bearing damage is done on a tight motor. NOT at normal temp and high rpm. You hurt it cold and THEN spit it out
[Re: gregsdart]
#2072589
05/13/16 01:51 PM
05/13/16 01:51 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
I am in the .003 minimum crowd as well.
[Re: Al_Alguire]
#2072595
05/13/16 02:00 PM
05/13/16 02:00 PM
Posts: 1,505 TN
SCATPACK 1
TN
I am probably wrong, but I thought from the factory, back in 68, motors came with .0025 clearance didn't they?
Old Geezer Racing
[Re: SCATPACK 1]
#2072602
05/13/16 02:13 PM
05/13/16 02:13 PM
Monte_Smith
North Alabama
I am probably wrong, but I thought from the factory, back in 68, motors came with .0025 clearance didn't they? Not sure why that would be relevant to this discussion
[Re: Al_Alguire]
#2072606
05/13/16 02:24 PM
05/13/16 02:24 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
I am in the .003 minimum crowd as well. I've ran a bunch of steel rod street and strip 7000 RPM motors with .004+ on the mains and .0035+ on the rods, no problems other than having 20 lbs oil pressure at 650 RPM idling in gear with 5W20WT oil at 180 +F oil temps, 30 lbs at 1200 RPM
[Re: Cab_Burge]
#2072668
05/13/16 03:48 PM
05/13/16 03:48 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I am in the .003 minimum crowd as well. I've ran a bunch of steel rod street and strip 7000 RPM motors with .004+ on the mains and .0035+ on the rods, no problems other than having 20 lbs oil pressure at 650 RPM idling in gear with 5W20WT oil at 180 +F oil temps, 30 lbs at 1200 RPM I agree. there is a old saying, "if you have too much clearance only you will know, if you have too little everyone will know". Joe
Without Data, you’re just another guy with an opinion.
[Re: gregsdart]
#2072715
05/13/16 04:45 PM
05/13/16 04:45 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
.0025" rods / .0030" crank / .0035 camshaft.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: Monte_Smith]
#2072768
05/13/16 05:47 PM
05/13/16 05:47 PM
Posts: 1,505 TN
SCATPACK 1
TN
I am probably wrong, but I thought from the factory, back in 68, motors came with .0025 clearance didn't they? Not sure why that would be relevant to this discussion Sorry I did not ask your permission before I asked my question, but It IS relevant Monte. Because if the factory could get away with .0025 clearance on a factory hemi, that had to be warrantied if it broke, then would it not be safe to assume .0025 was a safe clearance today with the better oil and metal we have available now? By the way have you ever destroyed the bearings in a motor you built that had clearances tighter than .003. Not trying to start an argument, just asking. Hope you have a blessed day
Old Geezer Racing
[Re: gregsdart]
#2072835
05/13/16 07:31 PM
05/13/16 07:31 PM
Monte_Smith
North Alabama
No that wouldn't be safe to assume....... That was a street car, that was to be driven on the streets. Not make pass after high rpm pass on a race track. Racers "blueprinted" factory engines, which almost always included MORE bearing clearance than a street engine, as well as a multitude of other "improvements". If they were perfect from the factory, that would mean all one needed to do was drop it in a car with proper gearing etc and go set stock class records. THAT didn't happen.
As to your other question, answer is NO, because I don't build anything tighter than .003 and never have. But we have recently seen several posts about destroyed engines on this forum, with engines that were what I myself consider "tight". Many have the same response as you, "well the factory....". Personally, I don't care what they did at the factory, because everything we do to a performance engine is to make it BETTER than factory. Also, speaking of factory, talk to some techs that actually worked at dealerships in the 60s and 70s. Spun bearings were very common in Hemi and Six Pack motors that were thrashed hard on the weekends.
You want to set YOUR engines up to factory specs, or tight, or whatever you want, that's fine.........but the OP asked for opinions on a race motor clearance and that's what he got. Same as you, he can form his own conclusions.
Someone already repeated the tired old adage......."build it loose, nobody knows, built it tight, everybody knows". That rings VERY true
[Re: krautrock]
#2072845
05/13/16 07:49 PM
05/13/16 07:49 PM
MR_P_BODY
so is it the same for a street strip motor that's gonna see alot of street miles? .003-.0035 mains and rods there too? Basically.. yes... my currant 416 which is street/strip but maybe a bit more strip minded.. I built it .003/.003 with a HV oil pump.. its a 7200 rpm engine
[Re: krautrock]
#2072848
05/13/16 07:59 PM
05/13/16 07:59 PM
Thumperdart
State of confusion
My junk is roughly .025-.028 on the rods and .032-.035 on the mains.............
[Re: SCATPACK 1]
#2072890
05/13/16 09:15 PM
05/13/16 09:15 PM
Cab_Burge
I am probably wrong, but I thought from the factory, back in 68, motors came with .0025 clearance didn't they? I've had the priviledge to take apart several factory OEM 426 street Hemi, one 1968 and sevaral 1966 and one 1970, none of them had .0025 main bearing clearances, same on the rods.(more like .0038+ on the mains and .0030+ on the rods) That was using a inside mike for the bearing I.D. and then measuring the inside mike with the same outside mike used to measure the rod and main journals. Keep in mind these motor had been driven for some miles, one had over 42,000 miles on it, not sure about the true mileage on the others BTW, I have seen 318 motors that had less than .0030 on the mains, I had to scotchbrite the mains to make the cranks rotate on them due to slightly bent cranks on both
[Re: gregsdart]
#2072964
05/13/16 11:08 PM
05/13/16 11:08 PM
Thumperdart
State of confusion
My junk is roughly .025-.028 on the rods and .032-.035 on the mains............. I am guessing you run 2.200 rod bearings? Yes sir..........
