Motor Swap #2071186
05/11/16 12:19 AM
05/11/16 12:19 AM
Crete, Illinois
70408dart Offline OP
Crete, Illinois
Okay everyone I got a question. I have a 90 Ram 150 2wd and it currently has an 87 318 bolted to a 5 speed manual transmission. What I want to do is put a 90 360 and bolt it up to the manual trans. Now the 360 was originally bolted to an auto trans. So can I just take the fly wheel off the 318 and bolt it to the 360 and put it back together?
Re: Motor Swap [Re: 70408dart] #2071209
05/11/16 12:46 AM
05/11/16 12:46 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
No. The flywheel will need to be balanced for the 360, it has a different balance then the 318 does.
You will also want to be sure the 360 crank is machined for the pilot bushing for the 5 speed, most are, but some are not drilled deep enough, or machined smooth. Gene
Re: Motor Swap [Re: poorboy] #2071224
05/11/16 12:59 AM
05/11/16 12:59 AM
Crete, Illinois
Crete, Illinois
What's the process for getting the flywheel balanced to the 360? What do I have to do? Is there a possibility of getting a flywheel that's already for a 360?
Re: Motor Swap [Re: 70408dart] #2071345
05/11/16 10:44 AM
05/11/16 10:44 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
That's a pretty involved process. There's pics around the web showing the location/size/depth of the holes that need drilled in the back side of the flywheel to balance it for a 360, but I'd just buy the right flywheel. But it's not a bad idea to locate those pics so you can see if the one you're buying is properly balanced.
Re: Motor Swap [Re: 1E2C] #2071371
05/11/16 11:45 AM
05/11/16 11:45 AM
scratchnfotraction Offline
when I went manual 5 speed in my 85 truck (NV4500) I replaced the fly wheel with one from discount/auto 130$
I would do the same with a 90 360 engine, just buy a replacement flywheel that has correct balance.
what 5 speed do you have?
A535? NV3500? NV4500?
you might want to use the newer style pilot bearing for the 92-93 magnum engine D series trucks. ask for a pilot bearing for a 93 Dakota 5.2/5.9
it fits the crank hub and is a roller bearing. fits in the larger hub that the TC snout goes in.
if you use the smaller bronze bushing type you need to make sure the smaller pilot hole in crank is drilled deep enough to fit.
Re: Motor Swap [Re: scratchnfotraction] #2071973
05/12/16 11:55 AM
05/12/16 11:55 AM
Crete, Illinois
Crete, Illinois
Okay a new flywheel it will be. Which tranny I will have to look. Thanks for all the info.
