need help on thread size #2069257
05/08/16 11:58 AM
05/08/16 11:58 AM
europe
W
WBR Offline OP
WBR  Offline OP
W
europe
I'm bolting my sb 421/w9 engine together after a little freshen up. lost threads on head under the bar that attaches the valve gear. I need to order helicoils but need verification on the thread size on the 8 middle ones. UNC 7/16? Used to metric...
Street driven, 421 Sb, NA, 9.98/137
Re: need help on thread size [Re: WBR] #2069320
05/08/16 01:22 PM
05/08/16 01:22 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Mine are 7/16-14. Torque bolts to 65# with threaded inserts. 60# with tapped threads. This is specs from jesel's. Use thread sealer on the bolts that are over the intake runner.
Re: need help on thread size [Re: WBR] #2069329
05/08/16 01:30 PM
05/08/16 01:30 PM
europe
W
WBR Offline OP
WBR  Offline OP
W
europe
Thank you very much!!!
