Poly 318 4 speed? Bellhousing?
#2068298
05/06/16 02:13 PM
05/06/16 02:13 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
will a LA small block bell work with an A block motor? if not what would i need?
Hell Hath No Fury Like Mine
Re: Poly 318 4 speed? Bellhousing?
[Re: sixpacksteve]
#2068372
05/06/16 04:42 PM
05/06/16 04:42 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I agree.Swapped a LA into the 66 Charger Poly and it fit great.I think 1 bolt dosent line up.Been a while since we did it.Rocky
Chrysler Firepower
[Re: therocks]
#2068437
05/06/16 06:32 PM
05/06/16 06:32 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Correct. On the Poly, the two bolts below the locating dowels are the same distance center-to-center on driver and passenger side. On the LA motor, the passenger side bolt is in the same place, but the driver side bolt is located halfway between the Poly location and the dowel.
