Page 2 of 3 1 2 3
Re: Preview my "new" Standard-Port Victor heads (LOOOOONG!) [Re: sixpackgut] #2068636
05/07/16 12:57 AM
05/07/16 12:57 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Originally Posted By sixpackgut
http://www.lingenfelter.com/images/Largeview/LPECNCL92intake.pdf
This is what most everyone gets on a stock ls3
Pretty crazy stock flow #'s.. that's like a 600hp cyl. head.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Preview my "new" Standard-Port Victor heads (LOOOOONG!) [Re: sixpackgut] #2068689
05/07/16 02:33 AM
05/07/16 02:33 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Hate to make you feel bad but those LS3 numbers are way low
I don't feel bad. The Victors are what they are, and should be more than enough head for my POS.
Re: Preview my "new" Standard-Port Victor heads (LOOOOONG!) [Re: BradH] #2068727
05/07/16 09:47 AM
05/07/16 09:47 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Your junk always runs good when it does run. Im sure we lost some good tech advise over the past ?6 years because your car hasnt been running
Re: Preview my "new" Standard-Port Victor heads (LOOOOONG!) [Re: BradH] #2068854
05/07/16 02:38 PM
05/07/16 02:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The plan was to see how doable it was to get these std port Victors to flow an honest 350cfm without making them as big as the Hughes CNC version, which is advertised at 313cc, and had the intake port opening big enough to where Brad ended up having one of his M1 manifolds welded up so he could port match it to the CNC heads.
I wanted to do it without making the port opening any bigger.
The results posted are from a port with a runner volume of 294cc, and the port opening was left untouched.
I also checked the volume of the untouched head and it was 276cc.
It's really a shame that edelbrock decided to fill in the bowls on these heads.
At least 1/2 the time spent porting these things was wasted just getting the bowls opened up to a more normal size.
To confirm my observations about the ootb exhaust flow on #7 vs #1, here are the test results:
#7
Lift-------I/E
.100---64.2/51.0
.200--126.1/104.1
.300--183.4/143.8
.400--238.8/167.4
.500--281.6/174.8
.550--297.4/176.0
.600--311.8/176.0
.650--302.4/176.0
.700--308.4/176.0
.750--317.5/176.0
Re: Preview my "new" Standard-Port Victor heads (LOOOOONG!) [Re: BradH] #2068857
05/07/16 02:47 PM
05/07/16 02:47 PM
So. Burlington, Vt.
So. Burlington, Vt.
For comparison, here are some numbers from an ootb early version head from 2008.
Lift------I/E
.100---69.6/51.9
.200--143.8/102.9
.300--194.3/149.9
.400--247.7/184.7
.500--291.8/204.8
.550--311.0/212.6
.600--316.8/216.5
.650--324.5/220.4
.700--330.2/223.1
.750--334.8/224.3
Those early version heads were the best flowing ootb std port heads I've ever seen.
With some minor chamber work and some bowl blending they were easily into the 340's.
Now to get close to those numbers you have to do some fairly substantial porting.
The newer version might be "new", but IMO..... Not even close to "improved".
More like a BIG step backwards in terms of being able to buy a decent piece and getting impressive results ootb, or with minimal reworking.
Re: Preview my "new" Standard-Port Victor heads (LOOOOONG!) [Re: fast68plymouth] #2069317
05/08/16 01:15 PM
05/08/16 01:15 PM
BradH Offline OP
BradH  Offline OP
The end result, IMO, is similar to the Chapman 260 cc Stage VIs. I'd passed twice on opportunities to buy the Chapmans years ago, but always thought they had most of "the right stuff" for my type of build.
Re: Preview my "new" Standard-Port Victor heads (LOOOOONG!) [Re: BradH] #2069389
05/08/16 03:36 PM
05/08/16 03:36 PM
AndyF Offline
AndyF  Offline
Yeah, those Chapman heads were probably the top of the heap. Especially for a car like yours.
I think the new Trick Flows are also good but would be killer by moving the ports up. If they would extend the ports by 1/2 inch and move the ports up the same amount then it would be very close to the old Chapman heads. The ports can be moved up in the Trick Flow heads if a person is willing to do the work.......
Re: Preview my "new" Standard-Port Victor heads (LOOOOONG!) [Re: BradH] #2069525
05/08/16 07:35 PM
05/08/16 07:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
The Chapmans always escape my memory when talking about BB Mopar heads.
Probably because of their relative "unobtainium" status.
they were very nice pieces though.
I'd be pretty surprised if there aren't already more sets of TF BB Mopar heads in the hands of consumers than all the Chapman stage VI's combined.
Re: Preview my "new" Standard-Port Victor heads (LOOOOONG!) [Re: BradH] #2070408
05/09/16 11:00 PM
05/09/16 11:00 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Seems like a lot of work for nothing. I would run what you currently have unless you have a money tree in your backyard🤑🤑🤑🤑🤑🤑🤑
Re: Preview my "new" Standard-Port Victor heads (LOOOOONG!) [Re: BradH] #2071947
05/12/16 10:49 AM
05/12/16 10:49 AM
BradH Offline OP
BradH  Offline OP
The heads arrived yesterday, but I didn't get a chance to open one of the boxes until this morning. I'll try to take some pics in the next couple of days to show the finished rework of the heads compared to an OOB piece.
Re: Preview my "new" Standard-Port Victor heads - PICS NOW!!! [Re: BradH] #2073408
05/14/16 06:49 PM
05/14/16 06:49 PM
BradH Offline OP
BradH  Offline OP
OK, starting to upload pics (4:48 PM). Bear (bare?) with me...
Re: Preview my "new" Standard-Port Victor heads - PICS NOW!!! [Re: BradH] #2073411
05/14/16 06:55 PM
05/14/16 06:55 PM
BradH Offline OP
BradH  Offline OP
Stock OOB 72 cc Victor chamber & stock OOB intake ports w/ SuPerformance standard-port intake gasket.
Re: Preview my "new" Standard-Port Victor heads - PICS NOW!!! [Re: BradH] #2073413
05/14/16 06:58 PM
05/14/16 06:58 PM
BradH Offline OP
BradH  Offline OP
Hughes' CNC chamber mods vs OOB 72 cc chamber.
Re: Preview my "new" Standard-Port Victor heads - PICS NOW!!! [Re: BradH] #2073415
05/14/16 07:00 PM
05/14/16 07:00 PM
BradH Offline OP
BradH  Offline OP
Hughes CNC chamber, IMM valve job, PRH-ported bowls & runners.
Re: Preview my "new" Standard-Port Victor heads - PICS NOW!!! [Re: BradH] #2073419
05/14/16 07:07 PM
05/14/16 07:07 PM
BradH Offline OP
BradH  Offline OP
Ported intake runners w/o gasket, w/ Indy SR (std port) gasket, w/ Hughes Engines gasket, and w/ SuPerformance std port gasket. As you can see, the intake runner entry is a "true" standard opening.
Also wondering why Hughes sells their gasket as a combo standard / Max Wedge fitment when they don't put the sealing bead on the outsides of the ports wide enough for a MW port (only the raised roof can be accomodated).
Re: Preview my "new" Standard-Port Victor heads - PICS NOW!!! [Re: BradH] #2073424
05/14/16 07:10 PM
05/14/16 07:10 PM
BradH Offline OP
BradH  Offline OP
So, what about the early-version Hughes CNC'd 75 cc chamber heads I have, too? Here's a view of the later chamber w/ their CNC job vs. the earlier chamber w/ their CNC job & full CNC porting option.
Re: Preview my "new" Standard-Port Victor heads - PICS NOW!!! [Re: BradH] #2073429
05/14/16 07:15 PM
05/14/16 07:15 PM
BradH Offline OP
BradH  Offline OP
How much bigger is the entry of the Hughes CNC'd 313 cc (their advertised volume) "standard" runner than the PRH-ported 294 cc Victors?
Here's the Hughes head's intake entries w/o gasket, followed by the gasket I carved up as a template to match the CNC'd entries, followed by that same gasket shown on the "new" head intake entries.
Re: Preview my "new" Standard-Port Victor heads - PICS NOW!!! [Re: BradH] #2073434
05/14/16 07:21 PM
05/14/16 07:21 PM
BradH Offline OP
BradH  Offline OP
How close is the Hughes "standard" CNC port to a Max Wedge? Here's a an Indy MW gasket placed over their "standard" CNC port. I'd say it's pretty close in width (1.30" port vs 1.35" gasket), but close to .250" shorter in height.
Ironically, Hughes' own intake gaskets like I showed above aren't designed big enough for their own "standard" Victor CNC port.
Re: Preview my "new" Standard-Port Victor heads - PICS NOW!!! [Re: BradH] #2073438
05/14/16 07:26 PM
05/14/16 07:26 PM
BradH Offline OP
BradH  Offline OP
Some gasket size comparisons to go along w/ the gasket-on-ports pics
- Indy MW over my "hand carved" Hughes CNC "standard" port
- Hughes CNC "standard" port over SuPerformance standard port
Re: Preview my "new" Standard-Port Victor heads - PICS NOW!!! [Re: BradH] #2073441
05/14/16 07:34 PM
05/14/16 07:34 PM
BradH Offline OP
BradH  Offline OP
I think that's about all I have for pics.
Also, I just wanted to mention that guys like Dwayne Porter, Brian Hafliger, Brett Miller, and the rest of the people who grind on heads for a living really do seem to blend science & art together when they carve good ports from so-so castings. up
Page 2 of 3 1 2 3
