putn 318 magnum in 88 d150 how do I keep my injection? #206581
01/28/09 03:44 AM
01/28/09 03:44 AM
vidor texas
4nhemi Offline OP
4nhemi  Offline OP
vidor texas
I Have a 88 d150 with throtle body injection and swapping a 318 magnum out of a 92 dakota with mpi. What intake do I need to put the TBI on the magnum?
Or can I swap the computer,and under hood wiring harness from the dakota to the d150?
Re: putn 318 magnum in 88 d150 how do I keep my injection? [Re: 4nhemi] #206582
01/28/09 09:35 AM
01/28/09 09:35 AM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I think there's three options possible here.
1st option is to remove the heads and get them re-drilled for the "LA" engine bolt pattern. This has been talked about on this board several times lately. Then you could continue to run your existing TBI intake and injectors.
2nd option is to find a 92 or 93 d150 that has the 318 magnum and getting the underhood wiring harness for that vehicle. I can't guarantee that the wiring is 100% the same but it would be by far the closest. You'd also need the fuel pump and probably fuel lines from this trucks gas tank. MPI and TBI have different requirements.
3rd option is to buy one of Mopar's carburated intake manifolds for the magnum engine and then have an adapter plate made for the TBI.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: putn 318 magnum in 88 d150 how do I keep my injection? [Re: 4nhemi] #206583
01/28/09 09:45 AM
01/28/09 09:45 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I would not be interested in keeping the TBI setup in your 88. It's primitive. If you can you'd be much farther ahead putting the MPFI from the Magnum in place.
Don't be the exception.
