Re: castor reading
[Re: racerx]
#2065445
05/01/16 08:09 PM
05/01/16 08:09 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Castor is usually measured over a 20 degree swing using a magnetic gauge on the wheel hub. A coil over shock angle has no worth. If you have a strut front end, it might be a little difficult since you have a camber angle on the strut also.
[image][/image]
Re: castor reading
[Re: sgcuda]
#2065628
05/02/16 12:18 AM
05/02/16 12:18 AM
Posts: 7,506 Az
Crizila
Az
Castor is usually measured over a 20 degree swing using a magnetic gauge on the wheel hub. A coil over shock angle has no worth. If you have a strut front end, it might be a little difficult since you have a camber angle on the strut also. Actually, it's measured over a 40 degree swing. 20 degrees on ether side of zero (straight ahead).
Fastest 300
Re: castor reading
[Re: Crizila]
#2065667
05/02/16 01:22 AM
05/02/16 01:22 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Castor is usually measured over a 20 degree swing using a magnetic gauge on the wheel hub. A coil over shock angle has no worth. If you have a strut front end, it might be a little difficult since you have a camber angle on the strut also. Actually, it's measured over a 40 degree swing. 20 degrees on ether side of zero (straight ahead). This is true, and the digital one that I have from Longacre uses 15 deg sweeps.
