B-body calipers on A-body disc brakes? #206542
01/28/09 02:03 AM
01/28/09 02:03 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
My 1970 Dart currently has a disc brake setup that I swapped over from a '74 Dart. That means it has the 10.87" discs and the slider calipers with the A-body size 2.60" pistons.
My question is can I switch to the B-body calipers with the 2.75" pistons? Would I need different caliper adapters? Will it improve my braking if I go to the larger pistons?
Thanks for any guidance and info!
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: B-body calipers on A-body disc brakes? [Re: MadMatt] #206543
01/28/09 02:14 AM
01/28/09 02:14 AM
AndyF Offline
AndyF  Offline
No need for B body calipers, just use the later model A body calipers. They all changed to the 2.75 piston in '75 or '76. Most rebuilt calipers will have the larger pistons in them.
Re: B-body calipers on A-body disc brakes? [Re: MadMatt] #206544
01/28/09 10:58 AM
01/28/09 10:58 AM
76(only) A body caliper is 2.75" but I'd measure what they pull out for you to make sure it isn't a 73-75 2.60"
Re: B-body calipers on A-body disc brakes? [Re: RapidRobert] #206545
01/28/09 12:34 PM
01/28/09 12:34 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
'76 A-body caliper is also the same as F,M,J body stuff.
Re: B-body calipers on A-body disc brakes? [Re: MadMatt] #206546
01/28/09 12:37 PM
01/28/09 12:37 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I have a set of 11.75 rotors new,but a little rusty,will clean up though.........
