Re: rear shocks
[Re: sam64]
#2065343
05/01/16 04:42 PM
05/01/16 04:42 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Best double adjustable you can afford.
The more I fool with shocks, the more important I see them being in the big picture.
Re: rear shocks
[Re: sam64]
#2065531
05/01/16 10:13 PM
05/01/16 10:13 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I like Afco double adjustable.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: rear shocks
[Re: dizuster]
#2065596
05/01/16 11:32 PM
05/01/16 11:32 PM
1967dartgt
Hilltown Pa
I'm all for the DA shocks. It was night and day for my car...but not at 10.80 on a pro radial...come on. Don't think it will hurt his performance, only help on poor tracks as you now can adjust both. If he decides to put a faster motor in he is already set with his shocks. Is it necessary no but niether are turbos on cars.
Re: rear shocks
[Re: sam64]
#2065768
05/02/16 10:36 AM
05/02/16 10:36 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
A set of double adjustable Vikings aren't all that much more than a set of Ranchos really.
Re: rear shocks
[Re: sam64]
#2066411
05/03/16 10:32 AM
05/03/16 10:32 AM
an8sec70cuda
sam64...the Vikings are cheaper. The owner told me they only make double adjustable shocks b/c they are no more expensive to manufacture than a single adjustable. The other companies just use that as a reason to jack the prices up for the doubles.
Re: rear shocks
[Re: sam64]
#2093578
06/17/16 04:43 PM
06/17/16 04:43 PM
Posts: 63 indiana PA
moparbob498
indiana PA
Not to hijack this thread but, I think I have a problem too, I run afco rears (da) & well I had one 1.23 - 60' time, then 1.38 to 1.41's now I was under car re plumbing fuel system & noticed the body of my shocks have dents in them? What the hell?, appears I have so much axle wind up they hit the tubes on rear end,.. I have no snubber, no ladder bars, just super stock springs, car is back halved- thanx for any input.
mopar or no car
Re: rear shocks
[Re: moparbob498]
#2093596
06/17/16 05:19 PM
06/17/16 05:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Not to hijack this thread but, I think I have a problem too, I run afco rears (da) & well I had one 1.23 - 60' time, then 1.38 to 1.41's now I was under car re plumbing fuel system & noticed the body of my shocks have dents in them? What the hell?, appears I have so much axle wind up they hit the tubes on rear end,.. I have no snubber, no ladder bars, just super stock springs, car is back halved- thanx for any input. How many clamps on the front segments... try doubling the clamps but the front segment isnt strong enough to stop the axle rotation.. I assume you dont have caltracs and even then they may not be strong enough to hold back the rotation... once you can stop the axle rotation then you need good shocks to control the axle
