A body 4 spd to auto ?'s #2064565
04/30/16 09:36 AM
04/30/16 09:36 AM
PA
maxwedge1 Offline OP
PA
after 20+ years of shifting gears im ready for an auto.
are the name brand trannies from the big box stores dependable?
727 or 904 behind a 416 smallblock ? will driveshaft length change? lokar the easiest option for kickdown cable?
Re: A body 4 spd to auto ?'s [Re: maxwedge1] #2064650
04/30/16 12:52 PM
04/30/16 12:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I wouldn't buy a performance trans from a big box store, Call John Cope.
904 will have to be built up but will use the same driveshaft , 727 will handle it better but you'll need to shorten the driveshaft.
Bouchilon for the throttle valve cable. Lokar is hit or miss, mostly miss, on working correctly.
Re: A body 4 spd to auto ?'s [Re: maxwedge1] #2064674
04/30/16 01:25 PM
04/30/16 01:25 PM
CA
crackedback Offline
crackedback  Offline
CA
If you have a 904, build it yourself, it's NOT hard to do. Building an engine is harder to do than a 904 or 727. Plus you learn a new skill and don't have to rely on someone else to do it anymore.
There are a bunch of videos, books and a really strong recipe cost about 300-400 for all the parts, many of which can be used over. One of my friends has this build behind a 525ish hp stroker hitting it with a 100-150 shot.
http://www.forabodiesonly.com/mopar/threads/904-race-tranny-recipe.256475/
Re: A body 4 spd to auto ?'s [Re: maxwedge1] #2064688
04/30/16 01:37 PM
04/30/16 01:37 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I have a Cope 727 behind my 340. 14 years and still working great.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: A body 4 spd to auto ?'s [Re: maxwedge1] #2065012
04/30/16 11:19 PM
04/30/16 11:19 PM
(1) 904 (2) yes (3) OE kickdown
