Re: csr scatter shield
[Re: mopar dave]
#2064066
04/29/16 03:31 PM
04/29/16 03:31 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
You just can't go faster than 10.0 w/ a blanket.
[Re: Roughbird72]
#2064132
04/29/16 05:57 PM
04/29/16 05:57 PM
an8sec70cuda
You just can't go faster than 10.0 w/ a blanket. I thought it was changed to 10.99 & quicker You may be right?
[Re: mopar dave]
#2064693
04/30/16 01:55 PM
04/30/16 01:55 PM
Posts: 1,237 North Central, Indiana
Roughbird72
Apparently so.
20.14 Section 20 - General Regulations 2:14 TRANSMISSION, Automatic/NHRA-Accepted All cars running 10.99 (*6.99) seconds and quicker must have an NHRA-accepted locking-type dipstick on the transmission. Any non-OEM automatic floor-mounted automatic transmission shifter must be equipped with a spring-loaded positive reverse lockout device to prevent the shifter from accidentally being put into reverse gear. Functional neutral safety switch mandatory. All transmission lines must be metallic or high-pressure-type hose. All vehicles running quicker than 10.99 seconds (*6.99) or faster than 135 mph (except some Stock and Super Stock classes as noted under Class Requirements) and using an automatic transmission must be equipped with a transmission shield meeting SFI Spec 4.1 and labeled accordingly. (“Blanket”-type shield, appropriately labeled as meeting SFI Spec 4.1, permitted.) All non-blanket-type shields must incorporate two (or one, per manufacturer’s instructions) 3/4 x 1/8-inch straps that bolt to the shield on each side and pass under the transmission pan, or transmission pan must be labeled as meeting SFI Spec 4.1. Permitted in all classes where an automatic transmission is used. Comp, Super Comp, Super Gas, 9.99 or quicker E.T. cars, and 135- mph or faster E.T. cars using an automatic transmission, Lenco Drive, or BRT must be equipped with a flexplate meeting SFI Spec 29.1 and covered by a flexplate shield meeting SFI Spec 30.1. Transmission that can utilize a high-gear transbrake must be supported by the use of two momentary buttons (one to arm the system, second as the main transbrake). Air shifter bottles must be stamped with DOT-1800 pound rating (minimum) and be securely mounted (i.e., no tie wraps or hose clamps).
72 Plymouth Roadrunner 11.08@123.25
