Power Nation/Engine Power 512? #2064154
04/29/16 06:25 PM
04/29/16 06:25 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Power Nation/Engine Power is building a 512" stroker.
Anyone know what cam they are using? Web page just says custom Comp Cams Hydraulic roller?
This is supposed to be using the trick Flow heads, and the parts listing have mention of using a Quick Flow 950 carb and the Go-EFI8 - 1200 HP TBI EFI?
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2064224
04/29/16 08:29 PM
04/29/16 08:29 PM
Jamie McGrath Offline
Should make good power without a lot of rpm.
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2064287
04/29/16 09:48 PM
04/29/16 09:48 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The "512" that's really a 505, if you go by what they said the bore and stroke is(4.350 x 4.250).
Based on what they said the lift was going to be(mid-.600's as I recall) my guess is it's either going to get higher than stock rocker ratio, or is using a "hydrid" lobe design that's really a solid roller profile that can be run with hyd roller lifters....... Or maybe both.
Re: Power Nation/Engine Power 512? [Re: fast68plymouth] #2064358
04/29/16 11:18 PM
04/29/16 11:18 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yep. I was yelling at the tv. "IT'S A 505 YOU IDIOTS!
Surprising since the older dude is pretty sharp.
They skipped a week and run a pig of a 390 Ford this last episode...
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2064556
04/30/16 08:38 AM
04/30/16 08:38 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
If I remember right it was in the .660 lift range. Didn't catch duration. But I'm old and forgetful too.
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2064721
04/30/16 02:35 PM
04/30/16 02:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
Yeh, one of my buddies was mentioning the 390 ford was kind of a mutt for the sum of the parts that were used.
They did a 350 Pontiac last year that was also pretty weak.
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2064757
04/30/16 03:35 PM
04/30/16 03:35 PM
CA
crackedback Offline
crackedback  Offline
CA
The dog of a BB mopar they built for that Dana White car was seriously lacking.
Re: Power Nation/Engine Power 512? [Re: 70VcodeCoronetRT] #2064803
04/30/16 04:51 PM
04/30/16 04:51 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i think they said 251/261@50.
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2064811
04/30/16 04:58 PM
04/30/16 04:58 PM
So. Burlington, Vt.
So. Burlington, Vt.
What would make what I would consider an interesting episode is to take one of these previous underwhelming builds and do some old school hop up mods to get the numbers up.
Take that 350 Pontiac, put in a bigger cam, pocket port the heads, different intake manifold, etc. something other than just putting a set of edelbrock heads on it.
Maybe rework the stock heads, then install the edelbrock heads afterward to see how much better they are.
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2065183
05/01/16 11:48 AM
05/01/16 11:48 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I wish my projects only took a 1/2hr to complete.... Can they said was 646/672
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Power Nation/Engine Power 512? [Re: 67mprfan] #2065250
05/01/16 01:50 PM
05/01/16 01:50 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Carb did much better than the FiTech fuel injection.
Thoughts on that?
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2065271
05/01/16 02:21 PM
05/01/16 02:21 PM
So. Burlington, Vt.
So. Burlington, Vt.
While I was watching the show I was thinking a carb would have made more power, but didn't think they'd try it.
The throttle response of the efi didn't look too good.
My guess for why it made less power is the a/f ratio the efi was chasing wasn't optimum for that combo and the carb was just closer to being "right".
It's a different dyno, so a true apples to apples comparison it's not..... But I tested a street 505 last fall. Rpm heads with a little clean up(way less flow than the TF's), xs290s solid cam with 1.5's, 6bbl.
Made 645tq/590hp.
I would have thought with the TF heads and intake manifold it would have made closer to 650hp, not to mention the extra .100 lift from the hyd roller they used.
I suppose with the carb on it the numbers were pretty close to what I would have expected, and the difference could just be the dyno.
Re: Power Nation/Engine Power 512? [Re: GY3] #2065286
05/01/16 02:48 PM
05/01/16 02:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thoughts on that?
CARBS RULE............Don`t tell Monte that........... laugh2
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2065303
05/01/16 03:20 PM
05/01/16 03:20 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I watched that this morning, loved the overhead view of the FiTech at full throttle but it was definitely down on power compared to the carb. I wonder how much tuning was done with the FiTech.
Re: Power Nation/Engine Power 512? [Re: ProSport] #2065312
05/01/16 03:35 PM
05/01/16 03:35 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I don't think they did any tuning just a timing change because they said the EFI was self learning.
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2065326
05/01/16 04:08 PM
05/01/16 04:08 PM
AndyF Offline
AndyF  Offline
The pump gas 470 engine with Trick Flow heads that Mopar Action did made a lot more power. Maybe Mopar Action should challenge Power Nation to a dyno shootout?
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2065349
05/01/16 04:47 PM
05/01/16 04:47 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
They suck at Mopars.
Mopar to the bone!!!
Re: Power Nation/Engine Power 512? [Re: AndyF] #2065353
05/01/16 04:57 PM
05/01/16 04:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
Maybe both of us should team up and challenge both of them work devil Show them what Mopars are really capable of work up
Re: Power Nation/Engine Power 512? [Re: Cab_Burge] #2065451
05/01/16 08:30 PM
05/01/16 08:30 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
It is amazing that those monkeys can throw together available parts and make decent numbers. They haven't in the past...
It is just an advertising tool for the manufacturers.
Re: Power Nation/Engine Power 512? [Re: 451Mopar] #2065551
05/01/16 10:40 PM
05/01/16 10:40 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I thought the second part airs next week?
I re-watched the first episode and they said the cam is a custom grind Comp hydraulic roller with 252/262 duration @ 0.050, 0.640" intake, 0.672" exhaust (no rocker ratio mentioned?), and 112 LSA installed at 112 intake centerline. Not sure who they did not advance the cam?
