intake manifold bolts weeping #2064016
04/29/16 02:27 PM
04/29/16 02:27 PM
Hangtowner Offline OP
On a 440 cast iron intake manifold, a couple of the bolt heads are weeping oil. The factory parts book is unclear to me if washers should be used under the bolt heads. I plan to put a light coat of Ultra rtv on the threads and reinstall one at a time to avoid a vacuum leak. Should I use hardened steel washers?
Re: intake manifold bolts weeping [Re: Hangtowner] #2064021
04/29/16 02:31 PM
04/29/16 02:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Washers wouldn't hurt, I wouldn't use RTV though. I wonder if you have a vacuum leak, what is drawing the oil against gravity ?
Re: intake manifold bolts weeping [Re: Hangtowner] #2064087
04/29/16 04:04 PM
04/29/16 04:04 PM
hooziewhatsit Offline
Definitely don't want RTV. When you remove the bolts later, little balls of dried stuff can fall into the engine and go where they shouldn't.
I use permatex high-tack to seal them.
Re: intake manifold bolts weeping [Re: Hangtowner] #2064102
04/29/16 04:50 PM
04/29/16 04:50 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The bolt holes are open to the oil inside the head / valve cover area.
I use ACE hardware #4047429 pipe thread compound on the bolt threads.
http://acehardwaremaldives.com/product/plumbing/4047429/#.VyOp6P5MHcs
It is supposed to withstand oil and gas and temperatures to 500 degrees.
Re: intake manifold bolts weeping [Re: Hangtowner] #2064128
04/29/16 05:52 PM
04/29/16 05:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Weeping intake bolts mean you're building crankcase pressure.
https://www.pegasusautoracing.com/productselection.asp?Product=3245
Re: intake manifold bolts weeping [Re: Hangtowner] #2064264
04/29/16 09:22 PM
04/29/16 09:22 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ehrenberg says they should be sealed with nothing but pipe thread sealant. Makes sense.
Re: intake manifold bolts weeping [Re: Hangtowner] #2064355
04/29/16 11:16 PM
04/29/16 11:16 PM
Ok, I will use pipe thread sealant. Thanks, guys.
Re: intake manifold bolts weeping [Re: John_Kunkel] #2064361
04/29/16 11:24 PM
04/29/16 11:24 PM
agreed, I would check the PCV system and leakdown %
Re: intake manifold bolts weeping [Re: Hangtowner] #2064414
04/30/16 12:21 AM
04/30/16 12:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Pipe sealant will take car of it.
Doug
