Re: intake manifold bolts weeping
[Re: Hangtowner]
#2064087
04/29/16 04:04 PM
04/29/16 04:04 PM
Posts: 3,909 Oregon
hooziewhatsit
Definitely don't want RTV. When you remove the bolts later, little balls of dried stuff can fall into the engine and go where they shouldn't.
I use permatex high-tack to seal them.
[Re: John_Kunkel]
#2064361
04/29/16 11:24 PM
04/29/16 11:24 PM
RapidRobert
Weeping intake bolts mean you're building crankcase pressure. agreed, I would check the PCV system and leakdown %
