Re: intake manifold bolts weeping
[Re: Hangtowner]
#2064021
04/29/16 02:31 PM
04/29/16 02:31 PM
Posts: 75,050 U.S.S.A.
JohnRR
U.S.S.A.
Washers wouldn't hurt, I wouldn't use RTV though. I wonder if you have a vacuum leak, what is drawing the oil against gravity ?
[Re: Hangtowner]
#2064087
04/29/16 04:04 PM
04/29/16 04:04 PM
Posts: 3,897 Oregon
hooziewhatsit
Definitely don't want RTV. When you remove the bolts later, little balls of dried stuff can fall into the engine and go where they shouldn't.
I use permatex high-tack to seal them.
[Re: John_Kunkel]
#2064361
04/29/16 11:24 PM
04/29/16 11:24 PM
RapidRobert
Weeping intake bolts mean you're building crankcase pressure. agreed, I would check the PCV system and leakdown %
