Re: csr scatter shield
[Re: mopar dave]
#2063303
04/28/16 12:31 PM
04/28/16 12:31 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I don't have a rule book in front of me, but it is possible, I suppose, for a Carbon Fiber part to age and become weaker in time. And just like a helmet that is out of date, it might fail under stress. But, I don't have that to worry me, because I will be using a metal trans shield in my project.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: mopar dave]
#2063320
04/28/16 12:58 PM
04/28/16 12:58 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I believe they do expire and have to be recert'd.
[Re: mopar dave]
#2063342
04/28/16 01:24 PM
04/28/16 01:24 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Knock on wood but in 40 years of racing I have never had anyone check a date on one of my transmission shields or flywheel shields. And I have attended both IHRA and NHRA fivisional races.
[Re: mopar dave]
#2063353
04/28/16 01:36 PM
04/28/16 01:36 PM
Posts: 11,683 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
5 years on a rigid shield. I think they want them back to look at because sometimes they get trimmed, modified, parts missing, etc., over time. Some manufacturers will only recert once. Call the manufacturer.
[Re: mopar dave]
#2063354
04/28/16 01:37 PM
04/28/16 01:37 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Yes, there still worth something. There are a lot of tracks that don't inspect that deep into certification on items, if at all. Even seat belts and helmets. If you got them your good to go. I just sold a out of date scatter shield for a glide for $60. Nothing wrong with it, looked brand new except for the the date.
[Re: rickraw]
#2063628
04/28/16 10:05 PM
04/28/16 10:05 PM
Posts: 22,721 Bitopia
jcc
Bitopia
Quality CF will outlast the driver, when only acting as an unused scattershield. The restraining belt will not, and is the time limited weak link in the design as for as aging out. But I don't believe its cf, more likely a kevlar composite, but will still last a lot longer then the belt.
[Re: mopar dave]
#2063891
04/29/16 11:12 AM
04/29/16 11:12 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
this I have is for small block, I'm going big block and no longer need this. it will be in the sale section soon. thanks I just gave away an outdated big block CSR shield that was given to me..... If this was a month earlier I would have traded you.
[Re: pittsburghracer]
#2063892
04/29/16 11:16 AM
04/29/16 11:16 AM
Posts: 1,237 North Central, Indiana
Roughbird72
Knock on wood but in 40 years of racing I have never had anyone check a date on one of my transmission shields or flywheel shields. And I have attended both IHRA and NHRA fivisional races. I always wondered how often/if ever the cert is checked or tech just checks to see if you have a shield.
72 Plymouth Roadrunner 11.08@123.25
[Re: mopar dave]
#2063917
04/29/16 12:04 PM
04/29/16 12:04 PM
Posts: 1,611 westerly, ri. usa
440lebaron
westerly, ri. usa
they expire 5 years from date on shield, CSR will recertify for $50, one time only,I did it last year gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: mopar dave]
#2064066
04/29/16 03:31 PM
04/29/16 03:31 PM
an8sec70cuda
You just can't go faster than 10.0 w/ a blanket.
[Re: Roughbird72]
#2064132
04/29/16 05:57 PM
04/29/16 05:57 PM
an8sec70cuda
You just can't go faster than 10.0 w/ a blanket. I thought it was changed to 10.99 & quicker You may be right?
[Re: mopar dave]
#2064693
04/30/16 01:55 PM
04/30/16 01:55 PM
Roughbird72
Apparently so.
20.14 Section 20 - General Regulations 2:14 TRANSMISSION, Automatic/NHRA-Accepted All cars running 10.99 (*6.99) seconds and quicker must have an NHRA-accepted locking-type dipstick on the transmission. Any non-OEM automatic floor-mounted automatic transmission shifter must be equipped with a spring-loaded positive reverse lockout device to prevent the shifter from accidentally being put into reverse gear. Functional neutral safety switch mandatory. All transmission lines must be metallic or high-pressure-type hose. All vehicles running quicker than 10.99 seconds (*6.99) or faster than 135 mph (except some Stock and Super Stock classes as noted under Class Requirements) and using an automatic transmission must be equipped with a transmission shield meeting SFI Spec 4.1 and labeled accordingly. (“Blanket”-type shield, appropriately labeled as meeting SFI Spec 4.1, permitted.) All non-blanket-type shields must incorporate two (or one, per manufacturer’s instructions) 3/4 x 1/8-inch straps that bolt to the shield on each side and pass under the transmission pan, or transmission pan must be labeled as meeting SFI Spec 4.1. Permitted in all classes where an automatic transmission is used. Comp, Super Comp, Super Gas, 9.99 or quicker E.T. cars, and 135- mph or faster E.T. cars using an automatic transmission, Lenco Drive, or BRT must be equipped with a flexplate meeting SFI Spec 29.1 and covered by a flexplate shield meeting SFI Spec 30.1. Transmission that can utilize a high-gear transbrake must be supported by the use of two momentary buttons (one to arm the system, second as the main transbrake). Air shifter bottles must be stamped with DOT-1800 pound rating (minimum) and be securely mounted (i.e., no tie wraps or hose clamps).
