Re: csr scatter shield [Re: mopar dave] #2064066
04/29/16 03:31 PM
04/29/16 03:31 PM
an8sec70cuda Offline
You just can't go faster than 10.0 w/ a blanket.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: csr scatter shield [Re: an8sec70cuda] #2064068
04/29/16 03:33 PM
04/29/16 03:33 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
that's fine as I don't race anyway, just T&T from time to time.
Re: csr scatter shield [Re: an8sec70cuda] #2064122
04/29/16 05:35 PM
04/29/16 05:35 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
I thought it was changed to 10.99 & quicker shruggy
72 Plymouth Roadrunner 11.08@123.25
Re: csr scatter shield [Re: Roughbird72] #2064132
04/29/16 05:57 PM
04/29/16 05:57 PM
You may be right? shruggy
CHIP
Re: csr scatter shield [Re: mopar dave] #2064693
04/30/16 01:55 PM
04/30/16 01:55 PM
Roughbird72 Offline
Roughbird72  Offline
Apparently so.
20.14 Section 20 - General Regulations
2:14 TRANSMISSION, Automatic/NHRA-Accepted
All cars running 10.99 (*6.99) seconds and quicker must have an
NHRA-accepted locking-type dipstick on the transmission.
Any non-OEM automatic floor-mounted automatic transmission
shifter must be equipped with a spring-loaded positive reverse
lockout device to prevent the shifter from accidentally being put into
reverse gear. Functional neutral safety switch mandatory. All
transmission lines must be metallic or high-pressure-type hose. All
vehicles running quicker than 10.99 seconds (*6.99) or faster than
135 mph (except some Stock and Super Stock classes as noted
under Class Requirements) and using an automatic transmission
must be equipped with a transmission shield meeting SFI Spec 4.1
and labeled accordingly. (“Blanket”-type shield, appropriately
labeled as meeting SFI Spec 4.1, permitted.) All non-blanket-type
shields must incorporate two (or one, per manufacturer’s
instructions) 3/4 x 1/8-inch straps that bolt to the shield on each
side and pass under the transmission pan, or transmission pan
must be labeled as meeting SFI Spec 4.1. Permitted in all classes
where an automatic transmission is used.
Comp, Super Comp, Super Gas, 9.99 or quicker E.T. cars, and 135-
mph or faster E.T. cars using an automatic transmission, Lenco
Drive, or BRT must be equipped with a flexplate meeting SFI Spec
29.1 and covered by a flexplate shield meeting SFI Spec 30.1.
Transmission that can utilize a high-gear transbrake must be
supported by the use of two momentary buttons (one to arm the
system, second as the main transbrake). Air shifter bottles must be
stamped with DOT-1800 pound rating (minimum) and be securely
mounted (i.e., no tie wraps or hose clamps).
