Re: new 500" stroker motor wont spin clear around?
[Re: turbobitt]
#206292
01/28/09 11:44 AM
01/28/09 11:44 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Did you check and make sure they took the piston stop out if they did degree the cam
[Re: dirt]
#206294
01/28/09 02:14 PM
01/28/09 02:14 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
we were just looking into the spark plug hole with a light shining in through the valve when it opens i can see half the piston and there was nothing i could see. i thought something may have fell into the exhaust valve and onto the piston. we even turned the motor on its side so if there was anything there on it it should slide over to the side i could see. the guy that built it says it spun when it left so if he takes it apart and there was nothing he did we would have to pay him. i dont blame him for that but if it was something we dropped in and he pulled the heads to get it the gaskets are $130 for the heads plus labor so i just wanted to be sure there wasnt something dropped in it.
If you have him do it be there when he disassembles it because if you aren't the next phone call will be looking for money because it wasn't his fault .
[Re: JohnRR]
#206295
01/28/09 02:52 PM
01/28/09 02:52 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
There's a reason I put my own stuff together...After some of the stuff I've seen I wish I could do all the machine work but thats just not realistic...
[Re: 1_WILD_RT]
#206296
01/28/09 02:59 PM
01/28/09 02:59 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Make sure the flex plate bolts to crank are not to long.
Don't ask me how I know....
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: sixpackgut]
#206297
01/28/09 04:32 PM
01/28/09 04:32 PM
Posts: 189 long island new york
kingdust
Ihave to assume you didn't turn the motor over on the stand,and I can't believe the guy who builds race engines would give you the motor that way! You mentioned bellhousing,if you put the flywheel on maybe the bolts are hitting the block, if not I would pull the pan down and see what's going on!
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
[Re: dirt]
#206298
01/28/09 05:14 PM
01/28/09 05:14 PM
kingdust
In my last post I said I can't believe an engine builder would give you the motor that wouldn't turn over. Their are engine builders who rip people off and I know few on long island who since moved out of state because nobody would deal with them anymore. That's why I said take the pan down and see for yourself and then take it back so he can't BS you! Good luck.
[Re: dirt]
#206303
01/28/09 06:58 PM
01/28/09 06:58 PM
Posts: 4,210 New York
polyspheric
New York
Call him up, tell him what happened. When he's done "explaining", tell him he has 24 hours to come over and pick it up, take it back to his shop, R&R it with new oil, gaskets, etc. and deliver it back again.
Unless, of course he wants to pay you $75. an hour to do his work for him?
If he refuses I'd like to know about it. Wayyy too many "famous name shops" have screwed up like this (including for magazine projects) and they were very careful not to let it get out.
I shoot my own dog.
Boffin Emeritus
[Re: polyspheric]
#206304
01/28/09 07:10 PM
01/28/09 07:10 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I'd reserve all judgement until the problem is found.Like what has been said,be there as it is being dis-assembled.Don't be surprised if some thing is found on top of a piston.Do you have or have access to a borescope?Do you know which cylinder is near the top of it's stroke when it locks?You can determine this by turning the engine until it stops,back it up and put your finger over the plug hole to feel pressure. Also if it's a blower motor,check your pully bolts on the front of the crank and make sure one is not interfearing on the timing cover.Check the same on the blower.
[Re: B G Racing]
#206307
01/28/09 09:00 PM
01/28/09 09:00 PM
Posts: 3,095 Idaho
Runner
Idaho
everyones always so quick to pass judgement.
[Re: Runner]
#206308
01/28/09 09:08 PM
01/28/09 09:08 PM
Posts: 1,397 Toronto Ontario, Can
Glen440
Its how they handle the problem that will tell alot about them. It could be a number of minor things.
87 dakota 6.1 hemi
