Page 4 of 4 1 2 3 4
Re: new 500" stroker motor wont spin clear around? [Re: hemigod426] #206329
01/30/09 01:09 AM
01/30/09 01:09 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
So when you get to look at the motor, look at the snout of the crank and look for a line at the begining of the radius, mine had a line around it where it cut into the crank alittle from installing the balancer. The fix was to take the crankgear to a friend who machined the radius in the crank gear. The problem was solved and my pullies lined up!...Phill
Re: new 500" stroker motor wont spin clear around? [Re: hemigod426] #206330
01/30/09 01:11 AM
01/30/09 01:11 AM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
I hope he pulled the timing cover first and didn't pull the heads off first?
Re: new 500" stroker motor wont spin clear around? [Re: Dodgeman67] #206331
01/30/09 02:00 PM
01/30/09 02:00 PM
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Any more news?
Re: new 500" stroker motor wont spin clear around? [Re: 9 Sec Phill] #206332
01/30/09 10:16 PM
01/30/09 10:16 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I'd be stopping by the machine shop to take a look if it was my engine.
Re: new 500" stroker motor wont spin clear around? [Re: 69Cuda340S] #206333
01/30/09 11:43 PM
01/30/09 11:43 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
the engine actually belongs to the guy who owns the car i am building now . i am just the person building the car . he picked this engine builder and took the motor to him so i am just kind of watching what is happening.
i would like to see the gear too or at least a picture. he is supposed to have the new gear ordered and we should have the motor back next week. i just wonder who is picking up the tab on it?
Re: new 500" stroker motor wont spin clear around? [Re: dirt] #206334
01/31/09 12:57 AM
01/31/09 12:57 AM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
Wonder if they used a crank key that was too tall and forced the gear over it splitting the gear in the keyway? Who supplied the gear set, the customer or the machine shop?
Re: new 500" stroker motor wont spin clear around? [Re: drag440] #206335
01/31/09 01:45 AM
01/31/09 01:45 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
good luck with Milodon.. bunch of dorks!!!
Re: new 500" stroker motor wont spin clear around? [Re: 70blackfish] #206336
01/31/09 08:26 AM
01/31/09 08:26 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
we just recently picked up a 512 stroker from a notable michigan engine builder and the crank was hitting the oil pickup boss.
WAXER
Re: new 500" stroker motor wont spin clear around? [Re: Dodgeman67] #206337
01/31/09 12:24 PM
01/31/09 12:24 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Excellent point. Would anyone here pull the timing cover off the motor before the heads? I sure wouldn't....unless there was something suspect there I knew about...
In the end it's all how he fixes the problem. Within' 2 days of you having the issue, the problem has already been found, and the new parts are on the way. As long as there is a $0 bill to go with it, that's about as much as you could ask for out of anyone...
Re: new 500" stroker motor wont spin clear around? [Re: dizuster] #206338
02/04/09 06:00 PM
02/04/09 06:00 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
any update...... I know when my engine first got fired up and after about 45 minutes of warm up there was a tapping noise under the VC's and the #4 cam bearing spun and no oil was getting to the rovckers and the got hot and stuck to the shafts.... the machine shop that did the work bought me new crane gold roller rockers and the engine builder re did the whole setup .... no charge at all ...
Mopar Performance
Re: new 500" stroker motor wont spin clear around? [Re: Glen440] #206339
02/22/09 10:03 AM
02/22/09 10:03 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
got the motor back friday. didnt charge anything to fix.
the gear on the crank for the gear drive had a crack in it.it was so small i could barely see it but the builder said that when i tturned it tried to expand and jamed it up. the crack was right where the key way was too.
guess we will see how it is after we get it fired up,keep my fingers crossed.
Re: new 500" stroker motor wont spin clear around? [Re: dirt] #206340
02/22/09 10:05 AM
02/22/09 10:05 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
well it is fixed as far as you know. i am sure he checked things 2x.now enjoy!
Re: new 500" stroker motor wont spin clear around? [Re: blownzoom440] #206341
02/22/09 10:27 AM
02/22/09 10:27 AM
Q
Quicktree Offline
Quicktree  Offline
Q
sounds like he took good care of you. to the builder.
Re: new 500" stroker motor wont spin clear around? [Re: dirt] #206342
02/22/09 10:37 AM
02/22/09 10:37 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
got a call. the builder said it was the timing gear on the crank for the gear drive. it was broke and came apart when he took the cover off.
we didnt even mess with it so thats pretty wild.
it was a milodon gear drive. never heard of that breaking on a motor that was never even cranked before!
he said he looked at his notes and he set the valve lash so he would have had to turn the motor when he built it and it was fine then. i am not sure who is going to pick up the bill for the tear down and reassembly. he called milodon to see what they said.
Tom had a similar incident. The snout on the 440source crank was on the higher end of the tolerance and we installed the lower Milodon gear. When we went to install the blower hub it wouldn't go on. so he tried to tap the lower gear off with a 1lb ball peen hammer and a chisel and the gear split in half. little too much tension from the tight fit I guess, oops. the gear was hard to install originally. He got another lower gear and he polished down the snout on the crank.
Re: new 500" stroker motor wont spin clear around? [Re: Quicktree] #206343
02/22/09 10:49 AM
02/22/09 10:49 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Page 4 of 4 1 2 3 4
