Re: 727 Transmission Problems
[Re: DodgeCharger]
#2062368
04/26/16 11:44 PM
04/26/16 11:44 PM
Thumperdart
State of confusion
Sound like it wasn't serviced cos the fluid doesn't just look like motor oil overnight............
[Re: dvw]
#2062497
04/27/16 03:00 AM
04/27/16 03:00 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The rear clutch is toast. It's the only component applied in all forward gears. Doug Yep no forward with the rear clutch gone. I take it you tried manual low also ? Ron
[Re: DodgeCharger]
#2062540
04/27/16 08:26 AM
04/27/16 08:26 AM
Posts: 9,847 MI, usa
dvw
MI, usa
What would cause the rear clutch to fail? Maybe a seal left loose? Cut or worn piston seal in the rear clutch, seal rings broken or worn on the input shaft, broken diaphragm spring in the rear clutch are the 3 most likely possibility's. Doug
[Re: DodgeCharger]
#2062549
04/27/16 09:08 AM
04/27/16 09:08 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
When I tore the splines out of the front planetary, I had no forward gears, but reverse still worked. Of course it was under full throttle, 1-2 shift, and made a loud bang when it happened
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: DodgeCharger]
#2062788
04/27/16 04:48 PM
04/27/16 04:48 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What would cause the rear clutch to fail? Maybe a seal left loose? Performance valve bodies raise the line pressure which puts extra strain on the rear clutch Belleville spring....not uncommon to see one fail shortly after overhaul since the seals are fresh and deliver full pressure to the spring. The one on the right is more susceptible to failure due to the long internal "fingers".
[Re: John_Kunkel]
#2063239
04/28/16 09:56 AM
04/28/16 09:56 AM
Posts: 19,456 north of coder
moparx
What would cause the rear clutch to fail? Maybe a seal left loose? Performance valve bodies raise the line pressure which puts extra strain on the rear clutch Belleville spring....not uncommon to see one fail shortly after overhaul since the seals are fresh and deliver full pressure to the spring. The one on the right is more susceptible to failure due to the long internal "fingers". should this part be replaced as a precaution ? i'm guessing there is no method to check other than a good visual inspection for cracks and to see the if the "fingers" are all the same heights.
[Re: 440Jim]
#2065897
05/02/16 02:01 PM
05/02/16 02:01 PM
Posts: 2,703 Mohnton, Pa
DodgeCharger
Mohnton, Pa
The seal was all torn up and no clutch material left on clutches. Explain the Bellevue spring. His transmission going by the case number looks to be a 1977. Wich Bellevue spring should he have? Looks like it should be improved?If it is the wrong one would it take out the seals? Thanks,
[Re: DodgeCharger]
#2065997
05/02/16 04:32 PM
05/02/16 04:32 PM
John_Kunkel
Rio Linda, CA
The piston casting numbers that Jim posted will tell you which piston goes with which spring. Even if the parts match is correct there's no way to tell if the spring is good. New is cheap insurance as is minimal clutch plate clearance.
[Re: John_Kunkel]
#2066074
05/02/16 06:44 PM
05/02/16 06:44 PM
dvw
MI, usa
John how tight can you run? Tighter than .025" Doug
[Re: dvw]
#2066089
05/02/16 07:07 PM
05/02/16 07:07 PM
John_Kunkel
Rio Linda, CA
You could probably get away with that but expect some creeping in Neutral.
