69 road runner survivor dash
#2061918
04/26/16 11:02 AM
04/26/16 11:02 AM
Posts: 1,107 Lynch Road
mro
Lynch Road
Hi - I'm starting the restoration on my 69 dash - does anyone have photos of survivor dashes or correct restored? My concern is holes. On my frame -which is original - there is a line of holes under the top - behind the pad - looks like for molding . Not sure if they were all drilled like that. I have the same holes on a coronet dashframe - and I would like to see what a correct dash looks like. thanks -
68 Satellite Wagon and a few other ones
Re: 69 road runner survivor dash
[Re: mro]
#2062204
04/26/16 07:35 PM
04/26/16 07:35 PM
Posts: 1,385 Az
69hemibeep
Az
Do you see them in this pic?
1969 Hemi Roadrunner 2nd owner
[Re: mro]
#2062319
04/26/16 10:34 PM
04/26/16 10:34 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
Are they thr holes underneith the over hang directly above the gauge bezel? If so, they should be there for trim
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: mopars_1]
#2062741
04/27/16 03:49 PM
04/27/16 03:49 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Are they thr holes underneith the over hang directly above the gauge bezel? If so, they should be there for trim There is no bright trim, other than the chrome ring that is installed on the gauge cluster, of a 69 Road Runner. Plymouth B bodies that have a plastic face over the steel dash ... Satellite , Sport Satellite and GTX have a piece of trim that goes all the way across the top of the dash , this piece is not on a Road runner or a Belvedere. photo borrowed from : http://a12mopar.com/yabb/Attachments/068.JPG
[Re: mro]
#2062743
04/27/16 03:53 PM
04/27/16 03:53 PM
JohnRR
U.S.S.A.
[Re: mro]
#2062990
04/27/16 09:43 PM
04/27/16 09:43 PM
mopars_1
Ridgeland Wi
Right, but those holes should be punched in regardless. Pretty sure even a 70 rally dash even has them
[Re: mopars_1]
#2063339
04/28/16 01:21 PM
04/28/16 01:21 PM
JohnRR
U.S.S.A.
Right, but those holes should be punched in regardless. Pretty sure even a 70 rally dash even has them Quite possible? I never really paid attention to that when I was parting cars, dash frame usually went to the crusher with the carcass ...
