Re: 413 with iron adjustable rockers
[Re: NicksGarage]
#2056991
04/18/16 05:48 PM
04/18/16 05:48 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
You sure you don't have a cam lobe going flat? I say that b/c the only time I've ever had a pushrod all of a sudden pop out and cause a problem was when a lobe was going flat on the cam. Especially since you say the rocker adjust was still tight.
[Re: NicksGarage]
#2056996
04/18/16 05:55 PM
04/18/16 05:55 PM
Posts: 1,611 westerly, ri. usa
440lebaron
westerly, ri. usa
I would think that factory adjustable rockers were for mechanical cams?? 413 or 426W gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: NicksGarage]
#2056999
04/18/16 05:58 PM
04/18/16 05:58 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Adjustable rockers & hydraulic lifter need a little shorter pushrod. 8.90" iirc. I'm sure Jegs, Summit, etc has em.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: NicksGarage]
#2057026
04/18/16 06:33 PM
04/18/16 06:33 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I actually had that happen to me when I was racing at Bremerton Raceways, but my adjuster was loose. I bent one pushrod and massaged it on the trailer frame, put it back together and ran all the valves. Then finished the day racing. Later I bought a new set of adjusting screws, locknuts and couple of spare pushrods. I wish I still had that car.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: jwb123]
#2057623
04/19/16 02:53 PM
04/19/16 02:53 PM
Posts: 4,127 Ramona, CA
NicksGarage
Ramona, CA
the cup depth and design varies from different push rod manufactures. I always put a 1/4 check ball in the cup and measure length with a caliper. You then can subtract 1/4 from your measurement to get correct push rod length. So the length is from the bottom of the cup to the other end. Sorry for all the novice questions but I've not dealt with this before. Looks like these are marine or HD truck application. Chrysler part number 2899597 might be the right thing.
[Re: NicksGarage]
#2057624
04/19/16 02:55 PM
04/19/16 02:55 PM
Polarapete
Graham, WA
The non-adjustable valve train from any RB motor will work in your application and I am sure there are many Moparts members that will be happy to swap parts with you Of course that is assuming you have a hydraulic cam...you could also do a cam swap to a mild cam like the repro Road Runner / GTX cam for a little more go. JMHO
[Re: NicksGarage]
#2057645
04/19/16 03:16 PM
04/19/16 03:16 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
The overall length is 9.060". Here is one of the straight ones. They are silver colored on the intakes and black on the exhaust, if that makes a difference. Can someone tell me what motor used these heads? Having a hard time finding any pushrods that match this. What is the casting numbers on both heads? As you know it should have had solid lifters in any of the pre 1965 letter sereis 300 motors, correct? On that pushrod yuo should be able to find aftermarket replacement pushrods for any RB 413,426W or 440 motor with hydraulic lifters and adjustable pushrods to replace the bent one, or you can send one good one in to Manton, Trend or Smith Bros and they will make you one, two or a set like it Let us know what you find and do BTW, one of my old 1958 300D convertables is, or was, in the Carpenter collection. I never own a wege powered one, I missed buying a cherry 1959 E convertable due to draging my feet back in 1964
[Re: NicksGarage]
#2057646
04/19/16 03:16 PM
04/19/16 03:16 PM
Posts: 4,457 Washington
madscientist
Washington
Call Smith brothers. Give them the measurements and they will hook you up. I would never go from what you have to a nonadjustable valve train.
[Re: NicksGarage]
#2057707
04/19/16 04:17 PM
04/19/16 04:17 PM
fast68plymouth
So. Burlington, Vt.
Be sure of which style lifter you have since the engine was rebuilt. The 1967 and earlier style hyd lifters have a pushrod cup that is smaller in diameter, and the pushrods for those years have one end with a noticeably smaller tip. If, when the motor was rebuilt, they used the more common 1968 and later style lifters, it should have the correct style pushrods to match the lifters.
[Re: NicksGarage]
#2058180
04/20/16 03:42 AM
04/20/16 03:42 AM
Cab_Burge
On a stock iron block with iron heads with a small or stock cam I would bring the #1 cylinder to top dead center on the firing stroke and then reset the lifter preload on both valves. I would feel and try twisting the pushrod before starting,(set one at a time) if it moves or not then loosen the lock nut on the adjuster a little at a time and lift on the rocker arm towards the valvs until you get a little bit of slop(up and down movement) between the adjuster tip and the pushrod. Once you have a little clearance slowly tighten the adjuster up while spinning the pushrod to determine when the clearances are at zero between the adjuster tip and the pushrod cup(take your time to make sure it is at zero with no preload or clearances ) When your sure and comfortable with the zero lash and zero preload add from 1/3 to 3/4 turn preload on the adjsuter and lock the lock nut down while holding teh adjsuter so it doesn't tighten up with teh lock nut . Adjust the preload on both valves and then rotate the motor over 90 degrees in clockwise motion looking at the front of the motor towards the drivers seat and set #8. If you want to do one side of the motor at a time then use the firing order to do that side, IE #1 firing at TDC is 270 crankshaft degrees away from #3 firing at TDC, # 5 is 180 degrees from #3 and #7 is 90 degrees away from #5. On the passenger side # 2 cylinder is 90 degrees before #1, #8 is 90 degrees after #3 and # 4 is 90 degrees after #8. #6 is 180 degrees from #4 IHTH and doesn't confuse the real issue of setting the lifter preload properly BTW, you will hear any where from 1/8 to one full turn of preload depending on that persosn likes and dislikes
[Re: NicksGarage]
#2058333
04/20/16 12:49 PM
04/20/16 12:49 PM
440lebaron
westerly, ri. usa
mopar performance pushrods hydraulic cam adjustable rockers P4876392 set P4876391 ea. gary
[Re: 440lebaron]
#2059205
04/21/16 06:50 PM
04/21/16 06:50 PM
NicksGarage
Ramona, CA
mopar performance pushrods hydraulic cam adjustable rockers P4876392 set P4876391 ea. gary Mopar Performance shows these having a ball end on both ends.
