Re: How strong is a sleeve in a stock block?
[Re: fbs63]
#2053595
04/13/16 12:58 PM
04/13/16 12:58 PM
Posts: 66 Oklahoma
66 Belvedere
Oklahoma
Stock eliminators usually use a larger bore block and sleeve it down. For example a 400 block sleeved to 383 bore size. You end up with a nice ridgid block because the cylinder wall thickness is INCREASED. Taking a 440 to 4.400 bore would take the majority of the original cylinder wall out. You would end up with a block that has no joining material between the cylinders. Not ideal for strength plus you have the stresses of 4 press fits. Boring it enough to clean up and relieve the cylinder walls at the top to aid flow will result in a much better engine. I agree. I was also asking why, and what his goal is. Ray
[Re: sgcuda]
#2053900
04/13/16 10:10 PM
04/13/16 10:10 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Ray
I wanted the extra cubes plus to unshroud my 2.25 intake valves that sit above a 4.380 bore already. I was thinking that there might be stronger materials available these days that would still allow the cylinders to have more strength than the original block I have. More worried about cracking a bore than cracking a web. Aluminum rods and aluminum caps should go a long way in protecting the bottom end. Final combination would be 4.40 bore by 4.40 stroke.
[image][/image]
[Re: sgcuda]
#2053981
04/13/16 11:54 PM
04/13/16 11:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You could do a partial fill then have it bored for the bigger bore with sleeves. I say pour it first because that tend to shrink back a bit from the bores.. if you pour it first then have it sleeved it would be tight to give more support since your talking a bigger sleeve........ JMO EDIT Might even think a tall fill since its race only
[Re: HardcoreB]
#2054240
04/14/16 01:21 PM
04/14/16 01:21 PM
Posts: 6,015 Salem
Grizzly
Moparts Proctologist
Salem
I posted this question on Yellow bullet some time ago...maybe worth a look under same name. What I gathered is at best it's a cap shoot and many capable shops argued which method was best. You're loosing column strength doing all 8 which may be corrected by brazing it all together afterward. ..And I used the word maybe. I've been fixing many things in my years and I believe there is always a way to skin a cat. My conclusion is in agreement with some here...get a better block. I planned on skinning my cat with Siamese sleeves.
Mo' Farts
Moderated by "tbagger".
[Re: sgcuda]
#2054304
04/14/16 03:18 PM
04/14/16 03:18 PM
Posts: 4,210 New York
polyspheric
New York
A question that I stopped asking because: 1. I never got an answer 2. it clearly made the clerk/machinist uncomfortable
If the sleeve isn't flanged (very rare now) the only force holding the sleeve in place is a light press fit (not rosette welding, splines, pins etc.). Since the combustion pressure is at least 700 psi, what prevents gas pressure from forcing the sleeve down in the cylinder except the head gasket? How much clamping force do the bolts exert against the sleeve as opposed to the deck?
Boffin Emeritus
[Re: polyspheric]
#2054398
04/14/16 06:33 PM
04/14/16 06:33 PM
Posts: 75,083 U.S.S.A.
JohnRR
U.S.S.A.
If the sleeve isn't flanged (very rare now) the only force holding the sleeve in place is a light press fit (not rosette welding, splines, pins etc.). Since the combustion pressure is at least 700 psi, what prevents gas pressure from forcing the sleeve down in the cylinder except the head gasket? How much clamping force do the bolts exert against the sleeve as opposed to the deck? There should be a step at the bottom of the bore, that is what holds the sleeve from going lower, if there is no top flange ...
[Re: JohnRR]
#2054475
04/14/16 07:30 PM
04/14/16 07:30 PM
Posts: 8,333 fredericksburg,va
cudaman1969
fredericksburg,va
If the sleeve isn't flanged (very rare now) the only force holding the sleeve in place is a light press fit (not rosette welding, splines, pins etc.). Since the combustion pressure is at least 700 psi, what prevents gas pressure from forcing the sleeve down in the cylinder except the head gasket? How much clamping force do the bolts exert against the sleeve as opposed to the deck? There should be a step at the bottom of the bore, that is what holds the sleeve from going lower, if there is no top flange ... The guy I talked too used top flange, a lip in the deck, the reason to deck after its done. He said it gives more area for head gasket and head to seal, stronger too. High nickel sleeves, much stronger then the block material.
