Those with a 10-point roll cage question... #2051604
04/11/16 02:26 AM
04/11/16 02:26 AM
Tennessee
WyleECoyote Offline OP
Tennessee
Did you ever need to get your headliner replaced after you had the cage in your car?
Is it even possible?
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Those with a 10-point roll cage question... [Re: WyleECoyote] #2051666
04/11/16 08:18 AM
04/11/16 08:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I installed my headliner after the cage. However none of the windows were installed yet. The cage is close enough to the roof that the front upper garnish moldings needed to be trimmed to fit.
Doug
Re: Those with a 10-point roll cage question... [Re: WyleECoyote] #2051831
04/11/16 01:52 PM
04/11/16 01:52 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have done literally done many cages with the headliners in place.Usually when you are close to the headliner you can use a sheet of aluminium or fiberglass with a asbestos backing or other flame retardent material like header wrap.
Re: Those with a 10-point roll cage question... [Re: WyleECoyote] #2051851
04/11/16 02:20 PM
04/11/16 02:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my Rampage it was a PITA being that my head
liner is the cardboard type.. it went in from
the windshield area(no windshield in it).. went
in on a angle then had to be turned into position..
a full cloth one is easier.. because you steam it
to shrink it tight
wave
