Engine Revs x Car speed #205106
01/26/09 07:33 PM
01/26/09 07:33 PM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hi guys,
does anybody knows the formula to calculate the car speed based on revs, gears, tires.... so on...
BR,
1973 Brasilian Dart
E100, boosted 390"
Re: Engine Revs x Car speed [Re: dart_73_br] #205107
01/26/09 08:52 PM
01/26/09 08:52 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yeah , heres my favorate. MPH x Gear x 336^ Tire Diameter = RPM
With the above formula you can pick Any Gear,MPH TD to get a RPM from the change. Plus its Easy to remember off the top of your head. The Key number is 336, after that its just gear TD and MP = RPM mike
Re: Engine Revs x Car speed [Re: Sport440] #205108
01/26/09 10:12 PM
01/26/09 10:12 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Don't forget to divide final RPM by 95-96% for converter slippage.
Here's a neat one to plug numbers into.......... Visual Speed/RPM Calculator
Re: Engine Revs x Car speed [Re: S/ST 3040] #205109
01/26/09 11:15 PM
01/26/09 11:15 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yep, dont forget about vert slip.
And Vic I remember that virtual calc, you gave us that link once before. I enjoyed it. It even came to mind when I first posted. mike
Re: Engine Revs x Car speed [Re: Sport440] #205110
01/26/09 11:27 PM
01/26/09 11:27 PM
S/ST 3040 Offline
S/ST 3040  Offline
I think that was done by a member here but, don't remember who it was.
