Dual battery set up what gauge battery cable #205043
01/26/09 06:38 PM
01/26/09 06:38 PM
Illinois
saukvillage Offline OP
Illinois
I have a dual battery set up and want to know if a 4 gauge battery cable would be appropriate for racing. What would be the prefer size cable for a nine second car.
Re: Dual battery set up what gauge battery cable [Re: saukvillage] #205044
01/26/09 06:48 PM
01/26/09 06:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Other than the BIG welding cable to the starter, I just run regular old standard size parts store stuff.....not sure what size it is but it`s been working/charging fine for many years.
Re: Dual battery set up what gauge battery cable [Re: saukvillage] #205045
01/26/09 09:43 PM
01/26/09 09:43 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I usually run 1 or 1/0 wire to the starter.
http://www.anaheimwire.com/GPT.htm
Re: Dual battery set up what gauge battery cable [Re: RobX4406] #205046
01/27/09 12:50 AM
01/27/09 12:50 AM
I also run multiple grounds off of the motor to the frame and firewall and two in the back for each battery
Re: Dual battery set up what gauge battery cable [Re: RobX4406] #205047
01/27/09 11:27 AM
01/27/09 11:27 AM
Illinois
Illinois
I am interested in more information on dual battery set-up. will more infor be listed for $$$$. how.rob1021@sbcglobal.net
Re: Dual battery set up what gauge battery cable [Re: saukvillage] #205048
01/27/09 11:46 AM
01/27/09 11:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The distance between the 2 batteries is the important
thing for the wire size, if under 4' a standard
battery cable is fine. If you dont know you will
be wiring them in paralell, + to + and - to -, this
will stay 12 volt but with greater cranking power.
I weld bolts to the chassis or frame for my ground
points, both in the rear(by each battery in your case)
and up front rear the engine(your using the chassis/frame
as the ground to the battery. Will you be running a alt
Re: Dual battery set up what gauge battery cable [Re: MR_P_BODY] #205049
01/27/09 12:15 PM
01/27/09 12:15 PM
Illinois
Illinois
Yes, I will be using an alternator.
Re: Dual battery set up what gauge battery cable [Re: saukvillage] #205050
01/27/09 12:25 PM
01/27/09 12:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My next question would be .... why the dual batteries,
do you have a problem starting. I know alot of guys
use the dual batteries because they dont use a alt
but if you are... why carry the extra weight, unless
its helping the weight transfer
Re: Dual battery set up what gauge battery cable [Re: saukvillage] #205051
01/27/09 12:51 PM
01/27/09 12:51 PM
United States
STLDuster Offline
STLDuster  Offline
United States
Check this out:
https://board.moparts.org/ubbthreads/show...rue#Post4924712
Wahoo! I ran over to AirGas down the road. They had 4 pre-packaged 25' 1Ga Heavy Duty Welding cable sitting off to the side. The best thing about it is that it is American made! It is "Radnor" brand, rated for 105 degrees Celsius (221 degrees fahrenheit)...
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Dual battery set up what gauge battery cable [Re: MR_P_BODY] #205052
01/27/09 03:34 PM
01/27/09 03:34 PM
Illinois
Illinois
Only because the car was set-up for two batterys; however, I don't have to go with dual battery, per your infor and now can save weight and $$$$. Thanks, 72 Demon 528ci Hemi 14 to 1 comp.
