Page 19 of 19 1 2 17 18 19
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #2048568
04/07/16 02:24 AM
04/07/16 02:24 AM
orrstown pa
lucky717 Offline
lucky717  Offline
orrstown pa
just adding .02 gm 2" shackles work instead off moving the bracket up
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #2049303
04/07/16 11:08 PM
04/07/16 11:08 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
I forgot I had done that on my tubbed 78, it made it real easy to lower the rear and no money out of pocket. up
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #2049436
04/08/16 02:17 AM
04/08/16 02:17 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
What era & model GM 2" shackles work on these? ~RT
Re: Pics of your lowered 72-93 Dodge trucks [Re: lucky717] #2050428
04/09/16 03:04 PM
04/09/16 03:04 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Lucky Have you seen my truck?
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #2117921
07/26/16 08:02 AM
07/26/16 08:02 AM
Missouri
8
84d150 Offline
84d150  Offline
Missouri
Originally Posted By 76dodgeboy
I think 245/45s are a bit short But Im not there yet. manna Locate a couple used ones for mock up but Im pretty set on being 27-28" tall with the tire. 245/45s are 26". I've mounted them in a v6 mustang before. I plan to sit close to the truck in the pic. No its not bagged in the pic. Its static. He has 20" Ram steelies
How did he get it that low static? This is the look in going for. Iv already got Dakota drop spindles. Debating on van Lcas. But besides ride quality vs spring cut is there any other benefit? It "looks" like the van Lcas still change camber and steering linkage angles the same as cut springs (with the same drop). Unless I'm wrong.
I want the engine cross member 1.5 or 2 inches from the ground. Or at least to tuck a 15 inch wheel to the fender lip. Or more. Which ever could come first? The back will be the easy part so any insight would be appreciated. Iv been scouring the Internet for info... Not much to go on... And it seems as if everyone is either pro street or only looking to go a few inches and maintain ride quality. Truck is just a weekend hot rod. I want it on the ground. Static.
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #2118337
07/26/16 06:26 PM
07/26/16 06:26 PM
Missouri
8
84d150 Offline
84d150  Offline
Missouri
Bump
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #2120382
07/29/16 04:03 AM
07/29/16 04:03 AM
Missouri
8
84d150 Offline
84d150  Offline
Missouri
Bump
Re: Pics of your lowered 72-93 Dodge trucks [Re: rickstershemi] #2687694
08/14/19 01:11 PM
08/14/19 01:11 PM
Wi
Littlered89 Offline
Littlered89  Offline
Wi
Hey all, I'm new here. I didn't see an introduction page so I'm jumping right in. I don't have a pic of my truck lowered but I want to lower it. I found a pic of a truck on Google and it lead me here. The pic was put in by "rickstershemi" I'm curious about the front spring perch flip. Any info you can give me is greatly appreciated. I have been looking for a way to lower the back end of my truck for about a year and haven't found a cheap way to do it yet. Thanks again.
Re: Pics of your lowered 72-93 Dodge trucks *DELETED* [Re: Kevin I] #2906965
04/05/21 06:46 PM
04/05/21 06:46 PM
Iowa
jon01 Offline
jon01  Offline
Iowa
Originally Posted by Kevin I
Kevin, what do you have for lowering components on your truck in these pictures?
68 Charger R/T - #'s matching car, 499/727/3.91
Re: Pics of your lowered 72-93 Dodge trucks *DELETED* [Re: jon01] #3025590
03/19/22 10:36 PM
03/19/22 10:36 PM
san jose,ca
sensi Offline
sensi  Offline
san jose,ca
Bringing this one back to quickly ask whether or not it is necessary to install van tie rod adjusting sleeves when you swap the van LCAs in?
Thanks in advance
Re: Pics of your lowered 72-93 Dodge trucks *DELETED* [Re: sensi] #3026265
03/22/22 04:54 AM
03/22/22 04:54 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I don't think you need that part from a van, but have you checked to see if it has the same part number/interchange?
