Re: factory six pack shaker 1971 challenger total restoration
[Re: NV69B7RR]
#2042538
03/31/16 09:36 AM
03/31/16 09:36 AM
Posts: 7,327 Toronto (YYZ) Ontario
YYZ
The attention to detail is amazing! Its gonna be a stunner when finished.
Looking at your window sticker, is your SPD on the fender tag 802? Super early production car. I think it might be B02 (November 2, 1970). There are more than a few 802 SPD cars kicking around but the VINs are all 1001xx. And there are at least 2 shaker Challenger ragtops within that batch.
[Re: YYZ]
#2044701
04/02/16 08:55 PM
04/02/16 08:55 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
factory door sticker is 10/70... FWIW.. one thing I remember was that it took 11 weeks from the date the order was placed to take delivery of the car. ALSO ON THE BOTTOM IS 10-27 B 80 ?
[Re: larry4406]
#2050614
04/09/16 08:55 PM
04/09/16 08:55 PM
ek3
Thanks for showing the trim ring stud repair details! I assume you use body filler on the top side of the stud?
Are the original studs cast as part of the ring or where the studs inserted into the ring as it was cast? Mine has a few broken studs. **** They are cast as part of the ring. The top is finished with an epoxy steel and /or filler can be used.. Very little is left to fill on the ring ! what is on the top in the photo is panel bond from the installation of the bolt.
