Re: Streetable Head Options? [Re: PurpleBeeper] #2048759
04/07/16 11:59 AM
04/07/16 11:59 AM
British Columbia Canada
Challenger340 Offline
Originally Posted By PurpleBeeper
The heads are 452's. It's a .030" over stock-stroke 440. Pistons are TRW L2295's, but the domes have been milled, so maybe it's just 10:1 with .035" head gaskets (?). It runs on 93 octane. I run 1-5/8" headers because the engine is mild & I destroyed one set of Hooker 2" primaries & two sets of Heddman 2" primary headers bottoming out on potholes. I have 4" more ground clearance now.
Definitely only need good head flow numbers only to .500" lift since the cam isn't any bigger. Aluminum heads would be nice if I can afford them for the extra "forgiveness" to nitrous and pump gas... if I can afford them. However, it would be stupid of me to spend $2000 on heads that slow the car down or have no affect, right?
Will trick flows/edelbrock/rpm/etc heads do me any good at .500" lift vs. stock? Slow the car down? Are larger valves worth the money at .500" lift? I'm thinking my options are:
1. bone stock 452's
2. home ported 452's
3. home ported 452's + larger intake & exhaust valve
4. aftermarket head
Everyone would like to have some new aluminum heads, but whatever money I save on the heads goes towards a second stage of nitrous or some lighter rods/pistons or ? Honestly, I think $1500 ready-to-bolt-on is more my budget...and that's a stretch....just skip lunch for 6 months.
The L2295's are only around 10.3:1 with their domes intact on an 88cc 452 head and .039" gasket.... assuming NO excessive Block Milling etc.? because they are built on a 2.029"C.D.,about .055" downhole @ TDC.
So given the above, and the fact that your domes are milled off, I would suggest more probably, you may currently be as low 9.3:1for compression instead of anywhere near 10:1 ?
As a general rule, many don't like Aluminum Heads at lower compression ratios, and it may be adviseable to run your Cam events against a cranking pressure test first, before entertaining an Aluminum head purchase to "see" what you are working with ?
ANY aluminum head ie: stealth /sidewinder, etc., is a flow improvement over any factory cast iron...
that said,
if you are indeed as I suspect down around 9.3:1 for C.R. ? and with the Piston .055" down the hole making quench up around .095"(.055"+ .039"gskt)... just say'in.... the benefits to the investment therein may be very limited in a head swap.
Better to be a "has been" than a "never was".
Re: Streetable Head Options? [Re: PurpleBeeper] #2048924
04/07/16 04:19 PM
04/07/16 04:19 PM
Chicago
PurpleBeeper Offline OP
Chicago
that said,
Good info Challenger340. My heads are milled .020" and the block is square-decked another .040" if I remember correctly. It knocks like crazy on 91-octane, but OK on 93-octane. I would love some aluminum heads, but I'm thinking they're not for me.
What would the larger intake/exhaust valves do for me? I've heard larger exhaust valves are a big plus for nitrous motors. Would my hardened valve seats need to be re-hardened or inserts put in if I put in larger valves?
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Streetable Head Options? [Re: PurpleBeeper] #2048958
04/07/16 04:38 PM
04/07/16 04:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
IMO, if you have to pay for new valves and the associated labor to install them, then do some blending, so you actually see some benefit from the bigger valves, then I'd just spend a little more and get new aluminum heads.
A set of Stealths or Sidewinders with a little clean up would come in at around your $1500 budget.
Re: Streetable Head Options? [Re: Challenger340] #2049050
04/07/16 06:22 PM
04/07/16 06:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By Challenger340
that said,
The 452 is an open chamber head so you forgot to include the depth of the open part of the chamber in your calculation ... add at least .100 , probably more like .110.
Re: Streetable Head Options? [Re: PurpleBeeper] #2049052
04/07/16 06:24 PM
04/07/16 06:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Without any bowl work ... lighten your wallet and not much else.
Talk to Dwayne about heads , he'll send you in the right direction.
Re: Streetable Head Options? [Re: PurpleBeeper] #2049119
04/07/16 07:21 PM
04/07/16 07:21 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Just get the sSealths from 440 Source. $500.00 per head ready to go.I believe that right now shipping might be free.
Re: Streetable Head Options? [Re: PurpleBeeper] #2049204
04/07/16 09:00 PM
04/07/16 09:00 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
The stealths do have free shipping. If you have $2000 buy the CNC stealths and be done. Those are the heads I am buying when I build my 512
eBay-cdwmotorsports
Re: Streetable Head Options? [Re: PurpleBeeper] #2049761
04/08/16 03:29 PM
04/08/16 03:29 PM
Cutting to the chase here....
IMO, your best option is to just spring for some Stealths or Sidewinders.
By the time you rebuild a set of cast iron heads, by anybody any good, done PROPERLY.... you have spent what the Stealth or Sidewinder would cost anyways ?
