Streetable Head Options?
#2047293
04/05/16 06:56 PM
04/05/16 06:56 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
OK, this subject has probably been beaten to death (sorry). I have a somewhat limited budget, maybe $1500-$2000 max for heads. What do you guys think are good street head choices?
10.5 compression with 452's, Comp Cams Xtreme Energy 21-224-4 274/286 duration, 488/491 lift, 230/236 duration @ .050", 110 lobe separation, 1-5/8" headers, six pack, 3.91's (likely going back to 3.23's or 3.55's since I don't have overdrive), 4speed, power brakes, power steering, no A/C, nitrous. I would like to run a faster 1/4-mile but keep the car completely streetable (99% street driven).
Should I home port some 452/906's? Larger valves? Edelbrock? Stealth? I'm "guessing" Indy & B-1 type heads would absolutely kill my bottom end. What do you think?
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
Re: Streetable Head Options?
[Re: PurpleBeeper]
#2047306
04/05/16 07:14 PM
04/05/16 07:14 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Thumperdart, I see your car is pretty fast. Do you run a cam as small as mine? How much to rpm's cost about?
Ice-Eagle, what makes you say stealth heads because I have a six pack?
Does anyone have some track data on the same car with different heads? Obviously, I'm looking for something "streetable" to compare with & not a blown alcohol engine.
[Re: PurpleBeeper]
#2047309
04/05/16 07:18 PM
04/05/16 07:18 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
352's ?? do you mean 452's ?
Do yourself a huge favor and shitcan the open chamber, iron head unless you race in a class that requires them or you have KB step head pistons already.
Sidewinders are a low cost upgrade , or the new trickflows.
[Re: JohnRR]
#2047314
04/05/16 07:24 PM
04/05/16 07:24 PM
Posts: 2,094 central texas
krautrock
central texas
i was just looking at what trickflows would be from summit if i could get a 20% coupon. then i remembered about the sidewinders. one difference beetween the two is 210cc vs. 240cc intake ports... with a small cam the sidewinders would probably be fine. here is a link http://www.mopartsracing.com/parts/Sidewinder.html
[Re: PurpleBeeper]
#2047327
04/05/16 07:44 PM
04/05/16 07:44 PM
Posts: 2,468 Sydney,Australia
tex013
Sydney,Australia
$2000 for the stealth CNC last time I looked
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: PurpleBeeper]
#2047330
04/05/16 07:47 PM
04/05/16 07:47 PM
Thumperdart
State of confusion
Does anyone have some track data on the same car with different heads? Obviously, I'm looking for something "streetable" to compare with & not a blown alcohol engine. I run an Isky solid roller .680-.660 276-281 @ .050 but drive this thing all over w/out any issues...........Bought em years ago and don`t remember the price sorry...........
[Re: Thumperdart]
#2047415
04/05/16 09:57 PM
04/05/16 09:57 PM
Posts: 4,694 Wichita
GY3
Wichita
CNC ported Stealths or Trickflows are very similar in performance.
Stealths are straight plugs whereas Trickflows have angled plugs Stealths have open combustion chamber whereas Trickflows have a little more modern designed chamber. Stealths look like a stock head on the end Trickflows do not.
I've run CNC ported stealths all over on the street and run 11's @ 117 mph with them in a car with 3.55's.
Both work equally well on a street/strip car.
[Re: PurpleBeeper]
#2047486
04/05/16 11:03 PM
04/05/16 11:03 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
How fast do you want this car to go on the motor and on NOS? What year and body style are you working on? The primary pipes size is probally going to limit how much power your motor will make on N/A as well as on the NOS I love 4 speed cars, I'm working on putting a 1966 Dodge Coronet Deluxe with a 440 motor and NP 833 O.D. tranny together this summer, I also have a 1969 Dart GTS 383 4 speed car to drive in the meantime To many toys and not enough time to enjoy all of them
[Re: LaRoy Engines]
#2048147
04/06/16 05:42 PM
04/06/16 05:42 PM
Thumperdart
State of confusion
Alum. is better in all areas imo and you can run pump swill w/less/no worries..............
[Re: PurpleBeeper]
#2048158
04/06/16 05:51 PM
04/06/16 05:51 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Has good flow numbers for you 6 pack. Pairs up really good.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: PurpleBeeper]
#2048263
04/06/16 08:14 PM
04/06/16 08:14 PM
Posts: 5,164 CT
GTX MATT
CT
What size engine is this, what do you run now, and what do you want to run? 1 5/8 headers are small if this is a 440.
[Re: PurpleBeeper]
#2048461
04/06/16 11:49 PM
04/06/16 11:49 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
The heads are 452's. It's a .030" over stock-stroke 440. Pistons are TRW L2295's, but the domes have been milled, so maybe it's just 10:1 with .035" head gaskets (?). It runs on 93 octane. I run 1-5/8" headers because the engine is mild & I destroyed one set of Hooker 2" primaries & two sets of Heddman 2" primary headers bottoming out on potholes. I have 4" more ground clearance now.
Definitely only need good head flow numbers only to .500" lift since the cam isn't any bigger. Aluminum heads would be nice if I can afford them for the extra "forgiveness" to nitrous and pump gas... if I can afford them. However, it would be stupid of me to spend $2000 on heads that slow the car down or have no affect, right?
Will trick flows/edelbrock/rpm/etc heads do me any good at .500" lift vs. stock? Slow the car down? Are larger valves worth the money at .500" lift? I'm thinking my options are: 1. bone stock 452's 2. home ported 452's 3. home ported 452's + larger intake & exhaust valve 4. aftermarket head
Everyone would like to have some new aluminum heads, but whatever money I save on the heads goes towards a second stage of nitrous or some lighter rods/pistons or ? Honestly, I think $1500 ready-to-bolt-on is more my budget...and that's a stretch....just skip lunch for 6 months.
[Re: PurpleBeeper]
#2048599
04/07/16 04:10 AM
04/07/16 04:10 AM
GY3
Wichita
Everyone would like to have some new aluminum heads, but whatever money I save on the heads goes towards a second stage of nitrous or some lighter rods/pistons or ? Honestly, I think $1500 ready-to-bolt-on is more my budget...and that's a stretch....just skip lunch for 6 months. What are you running with this current combo?
