Never trust someone about a roll cage #204703
01/26/09 10:34 AM
01/26/09 10:34 AM
nc
cold85 Offline OP
cold85  Offline OP
nc
I have had my dart for over 8yrs and ran many 6.30 passes with the current cage. The guy I bought the car from built it and told me everything was done correct. Well I could tell the way he ran some bars it would never pass tech but I thought it was good enough for running the times I was running. One spot he did not weld all the way around was thick tubing so I assumed it all was and did not ever drill in it. I did add some tabs and those places were thick wall. But I bought a new motor that is going to be way faster. So when I started cutting all the bars out for the new cage about 30% of the bars were thin wall almost like exhaust tubing.
Re: Never trust someone about a roll cage [Re: cold85] #204704
01/26/09 11:52 AM
01/26/09 11:52 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
What do you consider "thin"? What does it measure? What is the material? How was it welded? Please don't take this the wrong way but, how are you sure you are doing the cage the correct way? Using the correct materials, wall size, diameter, and welding techniques? You may have a good issue but, be more specific and throw-in some pics.
Re: Never trust someone about a roll cage [Re: HardcoreB] #204705
01/26/09 12:24 PM
01/26/09 12:24 PM
nc
cold85 Offline OP
cold85  Offline OP
nc
I have already hauled it all to the local scrap yard. It was no thicker than some exhaust pipe I had laying around the shop and in cutt out like butter. I am sending the car to a pro shop for a 12pt moly cage. the part that was not weleded was the top side of the cage in the car I guess they could not get the welder in there.
Re: Never trust someone about a roll cage [Re: cold85] #204706
01/26/09 12:36 PM
01/26/09 12:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
roll bar tube is easy enough to check. just find somebody with a sonic tester.
Re: Never trust someone about a roll cage [Re: Quicktree] #204707
01/26/09 12:55 PM
01/26/09 12:55 PM
nc
cold85 Offline OP
cold85  Offline OP
nc
I should have done that before I was stupid for taking the guys word for my safety
Re: Never trust someone about a roll cage [Re: cold85] #204708
01/26/09 01:05 PM
01/26/09 01:05 PM
nc
cold85 Offline OP
cold85  Offline OP
nc
here is a quick vid I did few months ago hard to see without good pics
]web page[/url]
Re: Never trust someone about a roll cage [Re: cold85] #204709
01/26/09 02:58 PM
01/26/09 02:58 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I guess he didn't know the trick on welding the top of the cage before installing it tight to the roof
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Never trust someone about a roll cage [Re: cold85] #204710
02/13/09 08:09 PM
02/13/09 08:09 PM
nc
cold85 Offline OP
cold85  Offline OP
nc
got the new moly cage in
Re: Never trust someone about a roll cage [Re: cold85] #204711
02/13/09 08:24 PM
02/13/09 08:24 PM
West Virginia
B1Frank Offline
B1Frank  Offline
West Virginia
Not every one's work is junk !! A person just need's to tell the truth in the story, when selling there car or buying one !!!by the way nice moly-cage !!
