Re: Question on rusty Gran Coupe convertible
[Re: 6pkaar]
#2046736
04/04/16 11:50 PM
04/04/16 11:50 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
And we all drove twisted up pretzel cars before the frame machine was ever invented.
Can you do it at home? Yes.
Is it easy, no it's tedious.
But it can be done right at home, just better pay very close attention to detail.
[Re: screamindriver]
#2046762
04/05/16 12:21 AM
04/05/16 12:21 AM
Posts: 821 NW Ohio
6pkaar
NW Ohio
If you're going to spend the money on all new major panels then it's worth the money to get the car to a frame machine... That's another question, I'm going to add frame connectors and everything I've read says to make sure the engine and rear end are in and it's on the wheels to make sure you have proper alignment. Were the convertibles built on the same numbers (frame machine) as the hardtops? Or did they add a little arch into the build to allow for flex?
[Re: 6pkaar]
#2047051
04/05/16 01:09 PM
04/05/16 01:09 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
The rockers on a Convert are stronger to make up for the missing roof structure. adding the frame connectors can be done whenever you want , just square the body before adding them.
It would be best if you could get the unibody on a surface plate , square and fix the structure first, then do the panel replacement.
