Re: molnar crank and rods machined quality?
[Re: mopar dave]
#2046889
04/05/16 05:58 AM
04/05/16 05:58 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
plan on dropping a lot of coin for a good digital one, I was looking at more than a grand for one that can measure in .0001 increments. Tim i would like to replace the analog gauge for a digital one. what brand of gauge would be affordable yet accurate enough to measure bearing clearance?
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2046975
04/05/16 11:36 AM
04/05/16 11:36 AM
Posts: 8,041 Mt Morris Michigan
mopar dave
Mt Morris Michigan
here is a $30 gauge with the same accuracy as the $300 gauges. same accuracy as my analog but i can read it easier as well. http://www.ebay.com/itm/0-12-7mm-0-5-0-01mm-Digital-Probe-Indicator-Electronic-Dial-Test-Gauge-/221842075927?hash=item33a6d17117:g:YRQAAOSwd0BVvVVD
[Re: mopar dave]
#2047092
04/05/16 01:59 PM
04/05/16 01:59 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
I prefer an analog gauge, graduated to .0001. That way, I can see it sweep towards zero, and very easily take a reading off the needle, without having to digest a bunch of moving numbers. IMHO, .0001 is essential, .0005 is too vague.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: mopar dave]
#2047340
04/05/16 08:00 PM
04/05/16 08:00 PM
BradH
Sounds like you got a good one. Read and heard from others that theirs were not as good as yours. I was hoping to use the crank right out of the box. I may take a harder look at scat. Curious what issues you've heard about Molnar products because all that I've heard has been that their quality is extremely good.
[Re: BradH]
#2047396
04/05/16 09:29 PM
04/05/16 09:29 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Sounds like you got a good one. Read and heard from others that theirs were not as good as yours. I was hoping to use the crank right out of the box. I may take a harder look at scat. Curious what issues you've heard about Molnar products because all that I've heard has been that their quality is extremely good. Same here Post a link
[Re: mopar dave]
#2047438
04/05/16 10:23 PM
04/05/16 10:23 PM
BradH
Without "outing" the senders of those PMs, can you post the pertinent info contained in them? Thanks - Brad
