Re: 727 clutch and manual valve body install
[Re: Adam71Charger]
#1951126
11/14/15 04:28 PM
11/14/15 04:28 PM
Posts: 25,955 Rio Linda, CA
John_Kunkel
Rio Linda, CA
That VB needs the piston installed.
[Re: Adam71Charger]
#1951130
11/14/15 04:44 PM
11/14/15 04:44 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Ok will do.
On to my front pump. I've taken the stator off and I'm ready to remove the old bearing. During removal the inner pump gear jumped out and now I don't know the correct position it needs to go into the outer pump gear, so I'm getting a new set.
I talked to a transmission shop and he recommended a babbitt or a dimpled bronze bushing but I'm not sure which one, I see many TC companies recommended babbitt . I can't find much info on dimpled bronze, why would I use it over babbitt?
[Re: Adam71Charger]
#1951155
11/14/15 05:55 PM
11/14/15 05:55 PM
John_Kunkel
Rio Linda, CA
I wouldn't replace the rotors if there's no damage.
Babbit bushings are softer so they don't wear the converter snout, bronze bushings wear longer but are harder on converter snouts....dimples act as tiny oil reservoirs but they decrease the actual bearing surface.
[Re: John_Kunkel]
#1951222
11/14/15 08:27 PM
11/14/15 08:27 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Glad you are not in a hurry to get this done. By the time you are finished and with the help of www.moparts.com you should know enough to build another one over a weekend.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Adam71Charger]
#2045664
04/03/16 08:51 PM
04/03/16 08:51 PM
John_Kunkel
Rio Linda, CA
There is no logical reason to leave the spring out unless you're installing the blocker rod described above.
[Re: Adam71Charger]
#2047169
04/05/16 03:29 PM
04/05/16 03:29 PM
Adam71Charger
After the new filter was installed i cleaned my pan and gasket surfaces to like new condition, made sure the pan was flat and installed a cork gasket dry to 95 in/lbs. The book calls for 150 in/lbs but 95 felt plenty tight for a tranny pan. After that I plugged up any holes and got to work cleaning the case from head to toe. I used Lacquer Thinner to get the surface clean, then primed and painted with high temp engine paint. Hopefully everything works ok when it goes in the car!
[Re: Adam71Charger]
#2047253
04/05/16 05:29 PM
04/05/16 05:29 PM
John_Kunkel
Rio Linda, CA
The plate in the VB blocks off the hole for the center bottom bolt. I thought about drilling it but decided against it and just left the bolt out
Once the governor is removed, there isn't a need for a perfect seal back there so a missing bolt doesn't matter. The 904 and 727 have different hole locations at that point, thus the elongated hole.
