Re: The "myth" of ram air.. does it WORK in cars/trucks?
[Re: jcc]
#2047081
04/05/16 01:47 PM
04/05/16 01:47 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
underhood = lower pressure near the windshield = higher pressure
the higher pressure air just moves into the area of lower pressure.
Considering most NASCAR noses are completely blocked off from incoming air and no scoops allowed, drawing air from the cowl is the most convenient spot I would think. But I ain't no engineer lol. Chevrolet did that with the '63 impala Z-11 cars. You really mean "Smokey"? They all had them. Maybe smokey came up with the idea, but it was standard on all the Z11 cars, even Ronnie Sox's.... http://www.streetlegaltv.com/news/muscle-cars-you-should-know-63-chevrolet-z11-impala-427/
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: GY3]
#2047132
04/05/16 02:46 PM
04/05/16 02:46 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
ok then. Red line is normal atmospheric pressure.where's the boost from ram air?
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2047138
04/05/16 02:54 PM
04/05/16 02:54 PM
Posts: 22,696 Bitopia
jcc
Bitopia
We have a different benchmark I guess for what makes a fact vs a myth then. All I see is colored graphs.
[Re: DARTH V8Я]
#2047178
04/05/16 03:39 PM
04/05/16 03:39 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Considering most NASCAR noses are completely blocked off from incoming air and no scoops allowed, drawing air from the cowl is the most convenient spot I would think. But I ain't no engineer lol. So, ram air works, eh?
[Re: feets]
#2047208
04/05/16 04:21 PM
04/05/16 04:21 PM
DARTH V8Я
Its a TRAP!
Considering most NASCAR noses are completely blocked off from incoming air and no scoops allowed, drawing air from the cowl is the most convenient spot I would think. But I ain't no engineer lol. So, ram air works, eh? In that sense, you're sure right buddy!
[Re: jcc]
#2047232
04/05/16 04:57 PM
04/05/16 04:57 PM
Posts: 30,995 Oregon
AndyF
Exactly, a couple of graphs with no explanation of what they are does not prove or disprove anything.
If you want to see ram air in action then call a Pro Stock team and ask them for a pressure reading from the air box during a 1/4 mile run. Or call up a NASCAR team and ask them the same info. Or to make it simple call Dave Braswell and ask him how much air pressure a Pro Stock carb sees in the lights and how it changes the AF ratio.
[Re: AndyF]
#2047257
04/05/16 05:34 PM
04/05/16 05:34 PM
DARTH V8Я
Its a TRAP!
If you want to see ram air in action then call a Pro Stock team and ask them for a pressure reading from the air box during a 1/4 mile run. Or call up a NASCAR team and ask them the same info. Or to make it simple call Dave Braswell and ask him how much air pressure a Pro Stock carb sees in the lights and how it changes the AF ratio. if you have contactinfo i'd call! i'd be curious to see exactly whats going on. Thanks good Sir.
[Re: DARTH V8Я]
#2047259
04/05/16 05:42 PM
04/05/16 05:42 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
Depending on scoop inlet area, as soon as the vehicle sees a specific velocity that creates a flow volume greater than the engines need at its specific RPM you will, from that point and accelerating further, have a positive pressure situation.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: DARTH V8Я]
#2047261
04/05/16 05:47 PM
04/05/16 05:47 PM
feets
Senior Management
Senior Management
Irving, TX
ok then. Red line is normal atmospheric pressure.where's the boost from ram air? What is the bottom value (X axis) and why are the graphs so different?
[Re: DARTH V8Я]
#2047266
04/05/16 06:14 PM
04/05/16 06:14 PM
DARTH V8Я
Its a TRAP!
Basically what this is saying is that +.34 Psi @ 14.21 psi = + 17hp difference IN FAVOR of ram air. Which is good. However air is incompressible at speeds below 230mph IE: 14.7psi @ sea level + xx value.
So the ram air does work at bringing the PSI close to atmospheric pressure of 14.7, but will not cross that threshold until ground or airspeed reaches at least 230mph.
So myth confirmed, to a point. My apologies, as I should have said ram air to create boost, as boost is defined as 14.7psi + xx.
[Re: DARTH V8Я]
#2047273
04/05/16 06:27 PM
04/05/16 06:27 PM
Posts: 9,824 MI, usa
dvw
MI, usa
So myth confirmed, to a point. My apologies, as I should have said ram air to create boost, as boost is defined as 14.7psi + xx. Exactly, you don't necessarily need boost to create more power, more flow will do that. However there are plenty of MAP readings out there showing above and below atmospheric pressure depending of configuration of the inlet. Do you think a knowledgeable racer would sacrifice aerodynamics of a protruding hood scoop if it slowed the car down? I think not. Do you think none of these teams test? Doug
[Re: DARTH V8Я]
#2047274
04/05/16 06:31 PM
04/05/16 06:31 PM
jcc
Bitopia
So myth confirmed, to a point. My apologies, as I should have said ram air to create boost, as boost is defined as 14.7psi + xx. BS
[Re: jcc]
#2047275
04/05/16 06:33 PM
04/05/16 06:33 PM
DARTH V8Я
Its a TRAP!
Thats it? Then what's your insight? Cause BS is the answer of a prepubescent teen.
[Re: DARTH V8Я]
#2047308
04/05/16 07:16 PM
04/05/16 07:16 PM
feets
Senior Management
Senior Management
Irving, TX
So myth confirmed, to a point. My apologies, as I should have said ram air to create boost, as boost is defined as 14.7psi + xx. So, who said it created positive manifold pressure at common race speeds? If it reduces the amount of vacuum in an intake then it has been successful. It does not require pressures above barometric. Air inlets of different shapes and sizes will create different pressures. Combine that with different air demands of different engine/chassis/speed combos and you're all over the board. As for JCC, don't try to make him think something he doesn't want to think. He has his own little ways of fighting for his preconceived notions. That's why I have him on ignore.
[Re: AndyF]
#2047324
04/05/16 07:43 PM
04/05/16 07:43 PM
Posts: 528 SW CO
HemiSportFury
SW CO
Something is wrong with your basic assumption that air is incompressible at speeds below 230mph. That statement is false, air is compressible at any speed. So that original statement needs to be run down and understood. I think it is causing all of your confusion. Agree with this statement, although it's been a long time since I got my ME degree. To the OP, please identify the source of your info? Seems to me there may be some confusion there since air absolutely is compressible, but in calculating line losses in fluid flow it was acceptable to treat air as "incompressible" within a small range. If the pressure drop (hence the change in density/volume) was too great you would you would have to break the system into smaller segments to do the calculations. Of course, that was back in the day when YOU actually did the calculations, and not just feed info into a computer that spits out a number.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: DARTH V8Я]
#2047334
04/05/16 07:53 PM
04/05/16 07:53 PM
DARTH V8Я
Its a TRAP!
[Re: DARTH V8Я]
#2047391
04/05/16 09:16 PM
04/05/16 09:16 PM
Posts: 528 SW CO
HemiSportFury
SW CO
From your source:
"the Mach number (the ratio of the speed of the flow to the speed of sound) must be greater than about 0.3 (since the density change is greater than 5% in that case) before significant compressibility occurs."
Key word: significant. It does not say it is not compressible, just not significant. So what everyone has been saying is correct, and there absolutely is a pressure change and a potential performance gain possible from ram air.
