Page 3 of 3 1 2 3
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040474
03/28/16 03:37 PM
03/28/16 03:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By Jeepmon
Thanks everyone for your advice and suggestions..
I really didnt want to spend the money.. specially with TAXES due next month and all the other projects we have going on.. but I ordered a set of scales today and will re-weigh the car..
Thanks again all
Yes just put it on the scales and move weight..
dont just add pre load.. that will just make you
turn left on the shut down.. then see what you
have... hopefully it will be level
wave
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040561
03/28/16 05:48 PM
03/28/16 05:48 PM
New York
polyspheric Offline
polyspheric  Offline
New York
So what size anti roll bar? Is it one size fits all for the diameter?
NO! The effect of an ARB varies as the 4th power of the diameter: a 1" bar is over three times as stiff as a 3/4" bar.
This will also vary greatly by the length of the link (or arm) to the chassis: longer softens bar action.
If you're adapting an existing bar, one with splined ends makes pre-load bias easy.
Boffin Emeritus
Re: Wheels up launch, adjustment question [Re: Jeepmon] #2040641
03/28/16 08:25 PM
03/28/16 08:25 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If it has chassis flex, no amount of adjustment is going to keep it from rolling over.
As for the tires....MORE air is going to wrinkle the tire HARDER as it puts more rubber on the ground and INCREASES bite. Looks like it has more than enough bite now........too much
Page 3 of 3 1 2 3
