Re: My trucks A/C gets warm at every stop light??
[Re: 5carguy]
#2037349
03/23/16 07:37 PM
03/23/16 07:37 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You checked for power at the fan? All you can do is start chasing the power backwards.
What kind of truck is it?
[Re: 5carguy]
#2037452
03/23/16 10:24 PM
03/23/16 10:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
no fan
Is the relay energizing?
That will point you where to look next
[Re: 5carguy]
#2037550
03/24/16 12:29 AM
03/24/16 12:29 AM
Posts: 5,899 ohio
ruderunner
ohio
No power at fan and new relay doesn't fix it. Pretty sure these set codes for auxiliary fan fault. Got a check engine light?
Look for a blown fuse in the meantime.
Angry white pureblood male
[Re: 5carguy]
#2037735
03/24/16 12:50 PM
03/24/16 12:50 PM
Posts: 2,592 None
71rm23
None
Yes,now the check engine light is on.I checked all fuses. Run it to an auto parts store. Have them put a scanner on it and check for codes and usually, FREE. It would least put you in the ball park or be dead on what is going on
